348 Possible 348 Transmissions Problem - Ferrari Life
post #1 of 3 Old 11-09-2014, 06:48 AM Thread Starter
Ferrari Life Posts: 27
I have noticed that if I suddenly let off the gas I get a definite clunk from the right hand axle area that sounds like it is coming from the area of item 4. Since I have the engine out for a major now is the time to check further. If I rotate each axle back and forth the LH side has no lost motion, conversely the RH side has a inch or more and a definite clunk that sounds like it is coming from close to item 4 on the attached drawing.
Before proceeding I would appreciate some recommendations from the FLife brain trust on the likely cause and how to correct. When I drained the gbox there was zero metal on the plug. I also poured the fluid thru a rag and did not see anything suspicious.
My initial guess is that bearing #3 on the attached drawing is failing.
Greatly appreciate any suggestions and, if possible links to a repair procedure. I have read multiple postings on transmission problems but have not found anything that sounds
like my concern.
Thanks,
Brewman
http://www.ricambiamerica.com/parts_...=&V=diag&I=232
Brewman is offline
post #2 of 3 Old 11-09-2014, 04:59 PM
Ferrari Life Posts: 11,859
B- Sounds more like a CV joint problem. Are the boots intact?
post #3 of 3 Old 11-10-2014, 06:02 AM Thread Starter
CV Joints Good
Taz,
That's what I was hoping. Both joints have been cleaned, inspected, greased, and installed with new boots. Problem still present.
Thanks,
Brewman
Brewman is offline
