348 CLUTCH - Ferrari Life
post #1 of 6 Old 01-09-2005, 01:25 PM Thread Starter
Ferrari Life Posts: 17
348 CLUTCH
Wonder if you could help - after my 348 (1990) has been running for about 10mins, the clutch stops working smoothly. When releasing the clutch after changing gear or trying to set off, it is impossible to do it smoothly. It's fine until the clutch is half engaged, but then it just drops the last half
boyce is offline
post #2 of 6 Old 01-10-2005, 03:04 AM
Ferrari Life Posts: 102
Maybe the clutch is wearing out (worn out)
This could be the friction material on the clutch plate or something else.
Could be a hydraulic problem also
Im not too sure about clutches.
Andrew
backindauk is offline
post #3 of 6 Old 01-10-2005, 01:28 PM
Ferrari Life Posts: 749
Contamination (eg oil) on the friction plate can produce a non-progressive clutch take-up, ie it suddenly just "grabs" with only a small amount of extra pedal movement. Is the clutch fully disengaging (ie is it hard to put into gear)?
4kids3fish is offline
post #4 of 6 Old 01-11-2005, 12:54 PM Thread Starter
I forgot to mention that the car has just had a full service and new clutch fitted.
boyce is offline
post #5 of 6 Old 01-11-2005, 12:58 PM Thread Starter
Appreciate your help, but, no, it is not difficult to select a gear, and, as i said, this only starts happening when the car has warmed up??
boyce is offline
post #6 of 6 Old 03-21-2005, 09:31 PM
Ferrari Life Posts: 5
I had a 92 with the dual plate set up and the travel was high and only about an inch of travel on the pedal, an almost binary feel.
This is a common thing for 348 clutches: they engage quite high on the pedal travel and over a short distance of travel.
Even after I rebuilt mine and had the system completeley bled, it was the same.
edit: sorry I'm not answering the question. have you checked the brake fluid in your reservoir?
vincent355 is offline
