328 Magic fuel pump fault - Ferrari Life
post #1 of 5 Old 04-28-2014, 09:36 PM Thread Starter
mehl's Avatar
Ferrari Life Posts: 64
Dear All, does anyone have an idea on this:
Car starts vey well aftrer very few cranks - hot and cold.
If you turn it off and want to turn it on again obviously the fuel pump is not switched on and I cant start the engine. This can last for a few minutes to several hous. Then again: Everythng fine, immediate start, after very few cranks. This happens with cold & hot engine.
On non faulty start I hear a well hearable "clonk" from the engine compartement like a big relay activated. Then I hear the whining noise from the fuel pump.
Is there a fuel pressure check switch stuck somewhere? Where ist it?
Is the fuel pump close to its end?
Help please!
Christian
mehl is offline
post #2 of 5 Old 04-29-2014, 08:04 PM
barcheta's Avatar
Ferrari Life Posts: 1,875
Looks as if you got lots of input from the other site. Check that fuel accumulator.
Current: 85' GTS QV
barcheta is offline
post #3 of 5 Old 04-30-2014, 09:28 PM
KKRace's Avatar
Ferrari Life Posts: 1,354
I put up a bunch of diagnostic info on this a while back. http://www.ferrarilife.com/forums/pr...l-pump-no.html
Life is Good!
KKRace is offline
post #4 of 5 Old 05-19-2014, 03:36 AM Thread Starter
mehl's Avatar
Thank you Kevin! Life is much better with good hints from the internet. It was exactly the connector behind that flap on the co drivers floor as pictured in #7 in your thread.
The short delay on the start of the fuel pump was obviously the time until the corroded connection pin heated up and gave good enough contact. No delay now, fuel pump is immediate on with ignition.
Thank you again , I'm very happy now.
Christian
mehl is offline
post #5 of 5 Old 05-22-2014, 10:33 AM
KKRace's Avatar
Christian
Glad to be of help. Others helped me so I felt I should pay it forward and combine the info into one place.
Life is Good!
KKRace is offline
