'76 ferrari 308 dino battery question - Ferrari Life
post #1 of 11 Old 06-29-2004, 08:03 AM Thread Starter
Ferrari Life Posts: 7
Ok, this may be really petty and I apologize in advance.
I have a 308 dino. is the battery supposed to be a standard 12 volt battery? the reason I ask is because when I hook one up, the horn works, but when I turn the key, I see the speedometer dials jump all the way to the end and back. i'm sure the engine of the car may be blown, but want to make sure before I ebay it..
thanks in advance!
itsmeek is offline
post #2 of 11 Old 06-29-2004, 09:58 AM
Ferrari Life Posts: 476
Yes, all cars use a 12 volt battery.
I don't know about your engine being blown but your wiring has a short in it. Does anything happen when you turn the key to the start position? Have you checked your fuse box and wiring? Have you tried cranking the engine directly from the starter?
senna21 is offline
post #3 of 11 Old 06-29-2004, 10:32 AM
Ferrari Life Posts: 36
Re: '76 ferrari 308 dino battery question
thanks in advance!
If memory serves, your car has been sitting outside since 1991? If this is the case, I am sure that there are connectors that have corroded and would need to be cleaned ... I'm amazed that the horn works! The early GT/4 is not known for having the world's best electrics, and corrosion of connectors can be a problem even in well maintained vehicles.
I agree that if you wish to try the engine that you could try it directly through the starter; however, there is some question as to what this will do to the engine of a car that has been sitting without oil circulation for over a decade.
If the engine is free, there likely be very little or no oil residue left on some very expensive parts and spinning the engine over will likely gall something that will cause the engine to need to be pulled to repair!
Have you changed the oil and filter? The old oil is probably not in the best of condition and over some 13 years of sitting outside will probably be something on the order of tar.
If it were mine, I would not try to turn the engine whether I planned on keeping the car or not. In my opinion, if the engine is not "bad" now, it will be if you spin it over.
Best wishes
confused 206 (Fiat Dino) is offline
post #4 of 11 Old 06-29-2004, 03:29 PM
Ferrari Life Posts: 749
As senna21 says, need to sort out the electrics first.
If you need to try the engine, before doing so I suggest the following:
1. drain existing oil & refill, change filter (I believe there's a Ford one which fits?)
2. remove all the spark plugs
3. put some squirts of engine oil into each cylinder via the plug hole (will need a flexy nozzle on an oil can)
4. squirt oil around the top-end (under cam covers) wherever possible
5. leave overnight
6. KEEPING PLUGS OUT, put car in 4th or 5th gear and push forward a few feet (gently). If the car can roll then this will turn the engine over a few times. Put in neutral, push back & repeat a few times to get the parts rotating.
7. If OK so far, KEEPING PLUGS OUT, hook-up starter & turn over. Turn for say 5 secs at a time, repeating after a few secs until you get a positive pressure reading on the oil-pressure gauge. If you can't get pressure on the starter then don't proceed further as it could seize.
8. If OK, check have fuel, put spark plugs in. This is the moment of truth! Have car in well-ventilated place as it will SMOKE something awful if it fires. Try starter. Keep rpm well under 2000. Run for say 20-30 secs max and then examine all over for problems (leaking gaskets, etc).
Good luck.
4kids3fish is offline
post #5 of 11 Old 06-29-2004, 04:34 PM
Ferrari Life Posts: 1,684
Do you mean a FIAT or a Ferrari?
Correct me if I'm wrong. There is no such thing as a 308 Dino, Ferrari. The last Dino model was the 246 Dino either in GT or GTS. The 308 is also either a GTB or GTS. There was the 208 GTB and GTS models but they were made for the Italian market.
Stradale is offline
post #6 of 11 Old 06-29-2004, 04:50 PM
Actually the first 308 gt/4 was a DINO rather than a Ferrari ...
1973 - 1975 or 1976 the 308 Gt/4 was built to continue the DINO line of cars being jointly built by FIAT and FERRARI since 1967.
In 1975 or 1976 the 308 GT/4 was called a FERRARI to bolster the FERRARI line of cars as there were few US legal FERRARI cars to sell due to the changing EPA and DOT rules and regulations. The GTB was added and was always a FERRARI as was the GTS.
Bests wishes
post #7 of 11 Old 06-29-2004, 04:59 PM
Andrew's Avatar
Ferrari Life Posts: 6,320
Here is a quick stats page:
http://www.ferrariforum.net/models/94
Sorry, no photo there but here is a photo:
http://www.ferrariforum.net/photos/view.php?id=616
Dino 308 GT/4
Andrew is offline
post #8 of 11 Old 06-30-2004, 01:35 PM
thanks in advance!
Where are you located? If you intend to put the car up on eBay, let us know ... there may be a member that is close to you that would be willing to buy the car.
post #9 of 11 Old 07-02-2004, 07:30 AM
Ferrari Life Posts: 5
Needles jumping up and down happens when the battery is low. Just recharge and try again.
Harry is offline
post #10 of 11 Old 07-04-2004, 08:39 AM Thread Starter
thats the weird part. the battery is brand new. who knows..i'm thinking the engine may be locked...the rear wheels do not spin even after i opened em up and released the front brakes. i couldn't get the rear wheels to turn...
itsmeek is offline
post #11 of 11 Old 07-04-2004, 06:07 PM
Is that in-gear or in neutral? If the wheels are still locked-up with gbox in neutral then it's a diff / hubs / brakes problem. If engine is seized then spinning one rear wheel forwards should make the other wheel spin backwards if the diff is working properly.
I'd concentrate on the drive assembly & forget the engine for the moment. If you can't get the wheels to spin by hand / wrench then starting the engine is only going to make things worse.
Try disconnecting the driveshafts from the transaxle if this is possible - can you spin any wheels then? If yes then the diff is locked-up, if not the the brakes/hubs are seized.
