308 GTS Electric windows wiring - Ferrari Life
post #1 of 3 Old 05-20-2004, 11:56 AM Thread Starter
I am helping to restore a 308 GTB glass body and helpinh to maintain a 308STS as a daily driver
the GST has the control for the Passenger's side elec window on the driver's side not working
This is a RHD vehicle so
X not working
W working
Door Position
Left Hand
Switch
W
Righthand
Switch
X W
So the onside passenger door switch is OK the offside passenger's switch is not
swapped the switches around and the switch itself works OK, assuming this is a wiring problem.
The passenger's switch is wired like so:
Y B
YB Arrow on switch downwards and on left
YB
B Y
Driver's side Passenger switch
BW B
Y Arrow on switch downwards and on left
Y
B BW
Y = Yellow
B = Black
YB = Yellow Black
BW = Black and White
OZFazza is offline
post #2 of 3 Old 05-21-2004, 02:28 PM
Ferrari Life Posts: 476
AHHHHH! 308 window motors. These have always been a problem from what I've read. You've eliminated the switches as the problem which is good. Now you have to do some more detective work. The 308's are known for having high resistance in the fuse box as well, just as a waring. Is the window motor working? Easy way to find out is simply apply (I'm assuming you have the door apart) 12volts to the motor. It should go up like a rocket. That will eliminate that as a problem. I've read about one person just wiring directly to the battery in order to have them operate quickly. The next thing to do will be to get a good Digital Multi-Meeter (DMM) and get to work testing resistance in the circuts.
Read this article:
http://www.motor.com/MAGAZINE/Pdf/032004_04.pdf
Once you're familiar with what you should be looking for (resistance) and how to find it, the job should be easyer.
Let us know how it goes!
senna21 is offline
post #3 of 3 Old 05-28-2004, 09:19 AM
OZFazza, any updates?
senna21 is offline
