F355 Problem reassembling F355 inner CV Joint - Ferrari Life
post #1 of 5 Old 08-31-2013, 11:48 AM Thread Starter
Ferrari Life Posts: 4
Replacing a torn inner CV boot on 355. I have the axle on a bench. The joint goes back together fine but after reassembly it does not move at all. I took it apart to see if there is more than one way to assemble it and it does not look like there is. All the balls go in, it just does not want to move side to side like CV joints supposed to.
Is there a trick? Suggestions???
I can post pics in a bit
GarageWarrior is offline
post #2 of 5 Old 08-31-2013, 02:13 PM
Is the joint still dry, or have you applied grease? If the joint is dry, it will bind. If you have the inner hub and outer cage flipped backwards, it will bind. Otherwise, it should work correctly.
post #3 of 5 Old 08-31-2013, 02:16 PM
KKRace's Avatar
Ferrari Life Posts: 1,354
Take it apart and put it back together again until it feels right. PITA to get them right but you'll know when you have it correct.
Life is Good!
KKRace is offline
post #4 of 5 Old 08-31-2013, 04:52 PM
Two ways to reassemble...
This way is correct. Notice the big sides versus small sides orientation....
post #5 of 5 Old 09-01-2013, 08:56 AM Thread Starter
Had it aligned backwards. Had to take it apart and realign the big sides with the small sides. Thanks for the help guys!
