F355 Need Help on my 1998 F355 Spider - Ferrari Life
post #1 of 6 Old 07-28-2013, 02:12 PM Thread Starter
Ferrari Life Posts: 4
My windows will not operate when the top is open, what's wrong?? Top operate fine,open and close with no issues. Windows operate as it should when top is up and closed but will not work when top is open. Another issue i have while opening top, 1st-release lever and then push top back till i hear beep 2nd-i push conv switch down to open and both windows goes down as it should 3rd- drivers seats moves forward BUT NOT PASSENGER SEATS??? what's wrong with it? I have to manually move my passenger seat forward and then press down switch to open top, once top is fully open drivers seat goes back automatic but not passenger and i have to use seat button to manually move seat back..
lovemy355 is offline
post #2 of 6 Old 07-28-2013, 02:42 PM
Passenger seat potentiometer is bad. It may also have a bad or mal adjusted lower position switch.
You will need someone with an SD1 or SD2 to diagnose and repair system.
post #3 of 6 Old 07-28-2013, 02:52 PM Thread Starter
Can you recommend a shop? App.. how costly is the damage?
post #4 of 6 Old 07-28-2013, 02:57 PM
Well since you have not filled out your profile I have no idea even which continent you are on much less what city you are near so it is a little difficult to recommend a shop.
I only estimate jobs after I have diagnosed them. I have not seen your car so I cannot give you a cost. You mechanic would be the best person for that information.
post #5 of 6 Old 07-28-2013, 03:18 PM Thread Starter
We're in washington dc can you recommend a shop? What about the windows, any clue why it only works when top is closed?
post #6 of 6 Old 07-29-2013, 01:06 PM
