308 Gasket Replacement Timing: How Much Time Do I Have - Ferrari Life
post #1 of 8 Old 07-20-2013, 10:42 AM Thread Starter
Dr Kananga's Avatar
Ferrari Life Posts: 33
Got the motor oil pan back in: studs replaced, sealing washers and fasters replaced the conventional ones, green gasket used, ...
1) How much time do you have between the first drop of gasket sealer and torquing the fasteners down?
The instructions say 'wait 1 minute before mating both surfaces'. Because the motor oil pan is such a pain in the ass to get back in, from bell to bell, took me about 5 mins.
2) I put the pan on, put on the fasteners, then torqued. I'm finding that the 'torquing' never ends. Should I wait til the seal is hard to get the final torque? Of course, I am using a torque wrench to set the correct torque, which is 78 in/pounds
Thanks!
Dr Kananga is offline
post #2 of 8 Old 07-20-2013, 01:01 PM
Pizzaman's Avatar
Ferrari Life Posts: 1,577
Interesting question.
Hopefully a professional chimes in on this.
Pizzaman is offline
post #3 of 8 Old 07-20-2013, 03:49 PM Thread Starter
Dr Kananga's Avatar
Or I will find out when I fill the car with oil, tomorrow, and spring/don't spring a leak.
post #4 of 8 Old 07-20-2013, 05:54 PM
Ferrari Life Posts: 97
Sir-
Not sure I'm right but, I torque mine down to spec,filled w/oil, ran engine up to normal temp, cooled down, and re-torque.
No leaks since. Good luck, bill
bill ward is offline
post #5 of 8 Old 07-21-2013, 02:12 AM
Hi,
It may be too late this time, but you should try Loctite 518, which is a fantastic gasket sealant which gives you all the time you need for assembly, because it doesn't start to set until air is excluded. I have had 100% success with this product.
Good Luck
Colin
Colin Angell is offline
post #6 of 8 Old 07-21-2013, 12:20 PM
Ferrari Life Posts: 11,858
Colin- Welcome to Ferrari Life.
post #7 of 8 Old 07-22-2013, 02:36 AM
Thank you, that probably means that was my first post here and I must admit that for some reason I am fairly new to Ferrari Life. Let me introduce myself. I am a past owner of a very nice 328, which I loved and for the past 11 years have enjoyed ownership of a 365 GTC. I carry out all my own maintenance and restoration so technical posts are always of interest, but primarily I am a driver and have driven many thousands of miles in these wonderful machines.
Thanks for the welcome
Colin
post #8 of 8 Old 07-22-2013, 04:53 AM
KKRace's Avatar
Ferrari Life Posts: 1,354
I guess a lot depends on what gasket sealer you are using? The best answer would probably come from the folks that made the sealer. I use RTV type sealers myself most of the time. If I have good flat mating surfaces I usually just put on a thin coat and torque whatever it is I'm working on right away. If I'm concerned about the mating surfaces like valve covers or headers sometimes I'll wait for the sealer to firm up a bit so it all doesn't squeeze out right away. But that is just my way.
Life is Good!
KKRace is offline
