308 308qv problem - oil on the spark plugs? - Ferrari Life
post #1 of 14 Old 06-27-2013, 05:04 PM Thread Starter
Ferrari Life Posts: 7
Hello
My beloved '83 won't start; first time in 7 years; always ran perfect. Checking the electrically etc; all good. Pulled a plug to check for spark...and it's covered with oil.
Now I'm nervous as this is the first time I've had to deal with a mechanical issue, and from my knowledge of cars (American although) this to me doesn't look good.
Thoughts/advice?
Kevin
Btw - also a thread on the other forum
Wolfgang5150 is offline
post #2 of 14 Old 06-28-2013, 09:12 AM
CaptOharry's Avatar
Ferrari Life Posts: 40
Wolfgang is it covering the Electrode or is the Cam cover gasket leaking?
CaptOharry is offline
post #3 of 14 Old 06-28-2013, 09:16 AM Thread Starter
Thanks for the response; I learned that its a gasket leak that has left a little in the bottom area. When I unscrewed the plug it ran down onto the plug.
Looks like a gasket seal. Thanks
Kevin
post #4 of 14 Old 06-28-2013, 09:49 AM
Ferrari Life Posts: 11,859
Kevin- Oiled plugs can also be a sign of poor ignition that is not burning off any accumulation. Check for spark at the plugs to eliminated that possibility.
Even though the engine will not start, you can do a compression test with a simple tool and see if the rings or valve seals/guides are shot. If you get low compression and add some oil on top of the piston and it improves, ring problem. If you add oil and nothing changes, valve sealing problem.
Since she will not start, hopefully it is an ignition problem.
The pros can probably chime in with a more in-depth answer.
post #5 of 14 Old 06-28-2013, 09:54 AM Thread Starter
Thanks; I pulled a plug and checked for spark; it didn't have any. I'm going to check (& learn) about the ignition more.
It has always run strong and has fired right up.
KEVIN
post #6 of 14 Old 06-28-2013, 10:00 AM
Kevin- That is a good sign. Ignition problems are much cheaper to fix than mechanical problems. There are some excellent upgraded ignition components available for the QV, too. Some of our pros can help you with that since they have experience installing those upgraded components.
post #7 of 14 Old 06-28-2013, 10:08 AM
Checking for spark in that way on any electronic system is very hazardous to the system and in itself can lead to a total ignition failure.
Proper diagnostic equipment is not made for the purpose of impressing our customers.
At least buy an inductive timing light. It is a reasonably cheap device that will test for the presence of a spark.
Also, on a QV you have two totally separate ignition systems. There are only two components that can cause both to fail. The RPM sensor and the ignition switch.
A non firing QV is usually fuel related.
post #8 of 14 Old 06-28-2013, 10:31 AM Thread Starter
Thanks; yes I'm treading very carefully as I diagnose this further.
Thanks for the advice
Kevin
post #9 of 14 Old 06-28-2013, 10:35 AM Thread Starter
Rpm sensor is located on the flywheel housing, correct?
post #10 of 14 Old 06-29-2013, 08:41 AM Thread Starter
For my own knowledge - why does it have two seperaely ignition systems?
Just curious
Kevin
post #11 of 14 Old 06-29-2013, 09:41 AM
Yes...at the 2:00 o'clock position
post #12 of 14 Old 06-29-2013, 09:42 AM
Just curious
Kevin
One reason is due to the speed of electronic technology (processing power) available at the time...
post #13 of 14 Old 06-29-2013, 09:49 AM Thread Starter
Thanks Dave
post #14 of 14 Old 06-29-2013, 02:14 PM
Like David said, the stuff was pretty crude back then, but even on the original 308 V8s, there were two distributors each running 4 cylinders. With points, it allowed for more dwell out of the distributor, although with CD ignition, all the points did was trigger the CD unit.
Even my 04 V12 and the latest V12s and V8s have two Motronic DMEs, one for each bank of four or six cylinders. Your engine is set up as two four cylinders on the same crank, unlike American V8s, which have cross-plane (90 deg) crankshafts. The flat/planar/180 deg crank on Ferrari V8s makes it easy to run them as 2 independent 4 cylinders.
