308 Fuel pressure regulator 308QV - Ferrari Life
post #1 of 3 Old 05-05-2013, 12:49 PM Thread Starter
Ferrari Life Posts: 37
Hi,
Can anyone tell me if the fuel pressure regulator should regulate against atmospheric pressure or not ? I am thinking of the little rubber hose at the end of the regulator. Should this be connected to the vakuum of the plenum or not ?
The part is a Bosch 0438161013.
The reason I'm asking is that in the workshop manual of the car it says it should regulate against atmospheric pressure. Am I wrong when I believe that this means not to the plenum ? Several mechanics says this can not be correct and that it should be connected to vakuum
To be fair,this is not a 308QV but a Lancia Thema 8.32 with slightly altered QV-engine
Thanks,
Arvid Andersson
Arvid is offline
post #2 of 3 Old 05-06-2013, 09:22 AM
The only place in a Ferrari where I see that part used is in the Swiss version of the 328.
In some cars it would be connected to vacuum and in some cars it would just be a vent, it all depends on the application and how they chose to use it on THAT PARTICULAR APPLICATION. Without access to a Lancia Thema 8.32 shopmanual it is impossible to comment intelligently.
post #3 of 3 Old 05-06-2013, 12:26 PM Thread Starter
Thanks Brian,
I assumed that this part was used in the 308 QV since the Lancia-version is almost equal. The only major differences I know of is the 90 deg. crankshaft,smaller valves and different firing order.
The fuel injection should be the same I thought. Apparantly not.
I have the workshop manual for the Lancia. It states that the regulator should regulate against atmospheric pressure. Which several mechanics dispute...
I am sertainly not sure what to think.
Arvid
Arvid is offline
