355 OBBII Tester code 1426 - Ferrari Life
post #1 of 2 Old 04-21-2004, 12:12 AM Thread Starter
Ferrari Life Posts: 3
I am looking at a SD 2 code book. I have code 1426 on my ODBII tester which I belive matches up with the SD 2 code.
The code refers to Evap. Emissions Control System Purge Control Valve
I looked in the 355 shop manual and am having a hard time inentifing which valve this is.
Is it possibily the canaster on the drivers side rear bumper location, and if is this the correct unit what is the best way to get at the unit to verify what the problem is?
8) 8
355Aloha is offline
post #2 of 2 Old 04-21-2004, 01:52 AM
Ferrari Life Posts: 1,684
Welcome Aloha. The 355 need the factory computer to re-set the car's ECU after any and every repair job. So it is unwise for you to attempt any repair job on it because it may cost you more in the end. :-?
Stradale is offline
