F355 Airbag warning light - Ferrari Life
post #1 of 1 Old 03-31-2013, 11:06 PM Thread Starter
Ferrari Life Posts: 12
Have an airbag warning light appear while driving 1995 Motronic 2.7 F355. Found the information in the workshop manual about the SD1 jack in the front of car and how grounding one of the pins for 1-5 seconds produces a 'lamp check'.
Can I assume that this 'lamp check' means the airbag light on the dash flashes the prescribed number of times for the issue present? I would also assume that I need to have the ignition on and in position II for this 'lamp check' to transpire?
Should I simply reset the warning, as indicated in the workshop manual, and see if it happens again?
Does anyone have any troubleshooting tips for an airbag warning?
I am still looking for a good SD1 reader option or the information about building one for myself if anyone has any suggestions there that would also be GREATLY appreciated.
Robert
directorcia is offline
