308 steering rack - Ferrari Life
post #1 of 17 Old 03-24-2004, 10:11 AM Thread Starter
Ferrari Life Posts: 67
308 steering rack
I have an 308 GTS from 1982 and the steering rack is worn out on the right wheel side.
Does anyone seen this before and is there any solution?
jags is offline
post #2 of 17 Old 03-24-2004, 09:01 PM
Ferrari Life Posts: 575
Worn-out in what way? Tie-rods, or the bushings in the rack itself? If its a tie-rod, its an easy repair, but if its a bushing in the rack, its a bigger job. Not sure if one could get bushings off the shelf from Ferrari (usually shops just replace the entire thing).
post #3 of 17 Old 03-24-2004, 09:33 PM Thread Starter
Its the bushing on the right side. If you take away the rubber hose you see the bushing is worn out for at least 2 mm.
Is this an steering rack from Ferrari or can it be replace by some other brand?
jags is offline
post #4 of 17 Old 03-25-2004, 08:44 AM
Spasso's Avatar
Ferrari Life Posts: 187
The bushings can be changed and there are upgrades available. I thought TRutlands had a kit for rebuilding these racks.
Jeff or Mark at FerrariUK may be able to offer a bushing kit also.
DJ
SPASSO
Spasso is offline
post #5 of 17 Old 03-27-2004, 10:11 PM
Originally Posted by jags
...Is this an steering rack from Ferrari or can it be replace by some other brand?
As far as I know, it's a specific Ferrari part (not made by them, but is unique to them).
I'm looking through my GT4 parts catalogue and unfortunately, they don't list internal parts available for the rack. The rack is listed as one part number (GT4 = 104498). It shouldn't stop you though from inquiring about the bushings with either T.Rutlands, or Ferrari of UK...
post #6 of 17 Old 03-28-2004, 02:35 AM Thread Starter
At T.Rutlands they just boffer an recondition rack and no spare parts.
I just have to look elswere i gues.
Does anyone have the website from
Ferrari of UK...
thanks in advance
jags is offline
post #7 of 17 Old 03-28-2004, 02:31 PM
Ferrari Life Posts: 11
I believe that Norwood's in Dallas sells upgraded/uprated steering rack bushing. James has always been very helpful.
seschroeder is offline
post #8 of 17 Old 03-29-2004, 10:25 AM Thread Starter
Hello everybody,
Big surprise; i found out that the steering rack is the same as in................a mini cooper !!!!!!
They even suplly service kits to recondition it.
So for all 308-328 owners, write it in your memory.
I let you know how it works out to rebuild the rack.
jags is offline
post #9 of 17 Old 03-29-2004, 11:47 AM
Pete04222's Avatar
Ferrari Life Posts: 5,509
Hello everybody,
Wow!! Is that awesome info to have! Thanks! Can't wait to hear how you make out.
Capt. Pete
Pete04222 is offline
post #10 of 17 Old 03-29-2004, 01:46 PM
Ferrari Life Posts: 749
I assume that is the current Mini, not a Morris/Leyland one! And how come a current vehicle uses a rack that was designed for a 70's car (308) ?? If I had a Mini I'd feel ripped-off :nuts:
4kids3fish is offline
post #11 of 17 Old 03-29-2004, 09:40 PM Thread Starter
The steering rack from the mini is from the model 1956 untill 1990.
So the rack is from a 1956 car.
Thats maybe the reason its wy its worn out :lol:
jags is offline
post #12 of 17 Old 04-05-2004, 08:13 AM
Spasso's Avatar
I found out from another source that the rack DESIGN and FABRICATOR is by the same source but the RATIO is different. To my knowledge the ratio is quicker in the mini rack. Installing one in a 308 would raise the low speed steering effort even higher than it is now!
Ferrari didn't actually buy up a bunch of old mini racks to use on the 308 but found the design was adequate for the 308 and contracted to have them built in the '70's with Ferrari specified ratios.
Sorry for the bad news. I was ready to buy one myself.
DJ
SPASSO
Spasso is offline
post #13 of 17 Old 04-05-2004, 10:43 AM Thread Starter
You are right about the ratio, you can not mount a rack from the mini because of different ratio but the good news is that you can get an revision set from the rack from the mini cooper and with this set you can repair the rack from a 308..
I keep you informed abaut the result and will make some photo's
Eddy
jags is offline
post #14 of 17 Old 04-05-2004, 02:26 PM
Isn't it amazing that a component built for a cheap 50HP 700 kg car with little 10" x 3.5" wheels (early Minis) could also handle the cornering stresses of a big 250HP Ferrari with fat sticky tyres. :nuts:
Britannia still rules the waves! :green:
post #15 of 17 Old 04-19-2004, 05:31 AM
Spasso's Avatar
Hi Eddy,
Any luck on your steering rack repair?
SPASSO
Spasso is offline
post #16 of 17 Old 04-19-2004, 07:58 AM Thread Starter
Didn't had the time to get the parts, will try to order tommorrow.
Keep you informed when we get it , will make pictures( everybody seems to love it) and let you know how it works out.
Eddy
jags is offline
post #17 of 17 Old 05-20-2004, 12:59 PM
FF3
Ferrari Life Posts: 3
Have exactly the same issue. Worn out on the right side. Could anyone provide me with a source for the revision set from the mini cooper rack ?
Thanks.
FF3 is offline
