Ferrari Life
-   Pre '99 V8s: GT4, 308, 328, 348, F355 (https://www.ferrarilife.com/forums/pre-99-v8s-gt4/)
-   -   F355 F355 fires (https://www.ferrarilife.com/forums/pre-99-v8s-gt4/14858-f355-fires.html)
drjavid 09-09-2011 06:10 PM
F355 fires
Thanks to another thread, I saw too many pictures of F355s that had caught fire and were totally destroyed. Is there a mechanical tendency specific to this model? Or is this a more general thing with super-performance engines?
Sandy Eggo 09-09-2011 06:21 PM
There was a fuel-block recall issued about 18 months ago. An improperly positioned hose clamp could eventually saw it's way through the fuel lines and send fuel spraying everywhere leading to almost immediate fire.
The recall was issued after a local San Diego F355 owner had perished due to this fault. :(
Likely, most of the fires you've seen or read about are due to this deficiency. F355 owners...if you haven't had the recall tended to...GET ON IT!!! If you're not sure if yours has been done - post a decent pic here of your engine bay and I can tell you in 5 seconds.
angus 09-11-2011 04:03 PM
Any chance you can outline what is done on this recall?
Sandy Eggo 09-11-2011 08:58 PM
Fuel block is replaced which helps move the fuel hoses just incrementally out of the way of the decklid hinges and coolant hose clamps to avoid chafing.
Here's the kit you can get for free and installed for free from the dealer...or you can buy it from Ricambi and do it yourself if you're reasonably competent.
Ferrari Parts : 70001495 : 70001495 F355 Fuel Block Recall Kit
There is a PDF on the Ricambi listing which describes the work, etc.
voila 09-24-2011 08:38 AM
2 Attachment(s)
5,4,3,2,1.. ;)
Thanks for having a look. I've been curious.
The first picture didn't show the sides, maybe you're looking for something in that area. The second is a little blurry, apologies, it shows a horizontal view.
Thank you Sandy Eggo !
Sandy Eggo 09-24-2011 11:18 AM
Originally Posted by voila (Post 152258)
5,4,3,2,1.. ;)
I believe yours has been done.
angus 09-25-2011 01:29 PM
My car had a leak due to deteriorated o-rings in the fuel hose ends, it almost looks like the rubber o-rings were the wrong material...
Sandy Eggo 09-25-2011 05:32 PM
IIRC, the recall kit provides for new o-rings.
voila 09-26-2011 03:28 PM
Thank you.
saw1998 10-01-2011 04:36 PM
Angus:
Are you in the US or UK? If the UK, do they also add (10%) ethanol to your pump gas
angus 10-01-2011 05:14 PM
Originally Posted by saw1998 (Post 153146)
Angus:
I am in canada, they do add ethanol to certain gas which I avoid buying.
However, the car came from the U.S. and who knows what gas others have used.
IF there is alcohol present then I am thinking the seals should be made from buna.
angus 10-01-2011 05:16 PM
Actually, the whole point of my story is that these cars can leak fuel from issues other than the hose being cut as outlined in the recall
