360 Door Panel Removal - Ferrari Life
post #1 of 3 Old 03-05-2009, 08:29 AM Thread Starter
Ferrari Life Posts: 3,627
360 DOOR PANEL REMOVAL
Taking apart the inner pull handle is done by unscrewing the Philips screw underneath the pull handle and then gently prying up the black "floor" in front of the handle to reveal another Philips screw. You can then slide out the black plastic molding.
On the bare inside of the armrest, under the edge of leather trim there is another heavy duty Philips screw securing the armrest to the inner door. At the end of the door, you can undo a small spring and then using a wrench unscrew the "locking" lever so you can slide the inner door pull handle out further.
In the handle pull mechanism is a small micro-switch. It is tiny consisting of a metal lever and small white button switch. One can use a q-tip to clean and lubricate it with WD-40 while the panel is off.
Gcalo is offline
post #2 of 3 Old 03-05-2009, 10:30 AM
Ferrari Life Posts: 6,204
I can hardly hold my enthusiasm
be still my heart
so, what this post needs is PICS.....step by step...inch by inch....
slowly I turn
post #3 of 3 Old 03-05-2009, 11:54 AM Thread Starter
No pics yet.
Gcalo is offline
