360 Front Bumper Removal - Ferrari Life
post #1 of 1 Old 03-02-2009, 10:50 AM Thread Starter
Ferrari Life Posts: 3,627
1) Remove the front wheels. Use appropriate jack stands to support the car.
2) Remove the plastic front wheel guards.
3) Open the trunk and remove the large black plastic cups. Under these cups are bolts to be unscrewed. Remove all four bolts
4) Under the front of car remove the screws holding the bumper to the front under floor panel.
5) Remove 2 bolts in front of wheel well in back of bumper on each side where the small square plate is.
6) Use 2Ē blue painters tape. Put 3-4 pieces on the bumper and on the body, and then with a marker pen draw a line straight down on both pieces of tape. You will want these to realign the bumper during reinstallation. Itís important and makes the reinstallation easier.
7) Make sure you have a large cloth under the bumper and have two people. The bumper will tend to tip downward as it is being removed. Be careful that it does not drop and scratch. Carefully pull the bumper off and rest on a large soft cloth out of your way.
8) Carefully re-install the bumper using the marks on the painterís tape as alignment points. As you begin tightening the bolts you need to make sure your space between the body and the bumper is uniform all around. Adjust accordingly checking your alignment points as well. This is a two man job.
9) Tighten all bolts and screws after alignment.
Gcalo is offline
