F430 F430 BANK 1 & 2 and SENSOR 1 & 2 ? - Ferrari Life
post #1 of 3 Old 12-13-2018, 11:08 PM Thread Starter
Ferrari Life Posts: 8
Quick question on banks and O2 sensors when it comes to error codes:
P0420 - Catalyst System Efficiency Below Threshold (BANK 1)
P0430 - Catalyst System Efficiency Below Threshold (BANK 2)
P2198 - O2 Sensor Signal Stuck Rich BANK 2 (SENSOR 1)
May I know, where is the system referring to for BANK 1 and BANK 2 ? And Sensor 1 and Sensor 2 ?
I have an image below illustrating the 2 O2 sensors (Green & Blue) on one side of the F430 engine:
Bank 1 refers to the RIGHT side of the engine and Bank 2 refers to the LEFT side of the engine ?
Sensor 1 refers to the PRECAT 02 Sensor (at the headers) and Sensor 2 refers to the POSTCAT 02 Sensor ?
I have an aftermarket high flow cat I know, but shouldnt this only trigger Sensor 2 and not 1, since Sensor 1 means PRECAT (at the headers) ?
unkle_uber is offline
post #2 of 3 Old 12-14-2018, 02:17 AM
Ferrari Life Posts: 2,395
Please have a look to this thread I posted a while ago where you can easily identify engine Banks & firing order
https://www.ferrarilife.com/forums/s...0-engine-banks
StefVan is offline
post #3 of 3 Old 12-14-2018, 06:25 AM Thread Starter
Hey Stef, thanks for pointing me to the right direction. Now I understand that Bank 1 is on the right side and bank 2 is on the left side. Sensor 1 also refers to the sensor right after the headers and sensor 2 refers to the sensor at the main cats.
Just to clear it up for anyone else facing the same question. I have a P2198 error code showing "O2 Sensor Signal Stuck Rich bank 2 sensor 1".
I would replace the O2 sensor to see if it helps even though I have high flow cats which should, theoretically only show sensor 2 being at fault.
