360 360 Noise on full steering lock - Ferrari Life
post #1 of 7 Old 12-12-2018, 10:28 AM Thread Starter
Ferrari Life Posts: 24
When I am on full steering lock, turning in/out of my garage there is a horrible noise coming from the rear passenger side of the car. Sounds like a belt or pump. Otherwise the car runs great. Is there a power steering pump or hydraulic pump back there that could be causing this? is it something else? Any ideas appreciated
whitby is offline
post #2 of 7 Old 12-12-2018, 11:32 AM
Ferrari Life Posts: 2,372
The power steering pump is indeed located right behind the passenger compartment - part #1. At full steering lock, like on any car, there is always a very common noise. If the noise you have is abnormally loud, maybe you should have the pump checked as well as the serpentine belt and tensioner.
StefVan is offline
post #3 of 7 Old 12-12-2018, 12:31 PM Thread Starter
Ok thanks. I suspect the belt. Is this not one that is changed every major service?
If not mine is original (15 years old) so tensioner and belt would likely be the culprit in that case
whitby is offline
post #4 of 7 Old 12-12-2018, 09:38 PM
You're very welcome. If your serpentine belt and tensioner are still the original, I would indeed start by replacing them. The timing belt is the one which is changed every major service.
StefVan is offline
post #5 of 7 Old 12-16-2018, 09:16 AM
If not mine is original (15 years old) so tensioner FMovies YesMovies SolarMovie and belt would likely be the culprit in that case
On a different topic, my center panel (hazard button, parking light button and the larger faceplate these are part of) are in need of refinish. What would the price be? Would you need mine specifically or you have some to already refinish? how hard is it to swap out these parts?
fouad2000 is offline
post #6 of 7 Old 12-16-2018, 11:02 AM Thread Starter
I 'fixed' mine with diluted rubbing alcohol and a microfibre cloth. Left a matt finish that is easy to keep clean.
whitby is offline
post #7 of 7 Old 10-15-2019, 11:38 AM Thread Starter
Finally got round to taking care of this - just been too busy. It turned out to be a leak in the low pressure power steering hose from the pump
whitby is offline
