F430 Drive Mode Switch - Ferrari Life
 1Likes
  • 1 Post By 2005F430OldGuy
post #1 of 5 Old 12-11-2018, 05:26 AM Thread Starter
Ferrari Life Posts: 5
Drive Mode Switch
Has anyone had issues with the Drive Mode Switch?
I had this message/logo come up intermittently, then on solid.
When the symbol was displayed, the little lights on the switch and mode indicator are not on, and the horn did not work. When the symbol went away, all worked including the horn.
Moving the switch to another mode did not matter. I disconnected the battery for a few hours and reconnected. Started and let idle for 30 minutes. Still has problem.
2005F430OldGuy is offline
post #2 of 5 Old 12-11-2018, 10:41 AM
Ferrari Life Posts: 2,397
Only a diagnostic tool like the SD3/DEIS or equivalent will tell the exact error codes stored in the impacted ECUs. Maybe you have a wiring issue in the steering wheel and/or column. Maybe you got a Can-BUS issue with one of the F430 ECUS or instrument panel cluster node. There can be many other reasons. I would start first pulling our the error codes.
StefVan is offline
post #3 of 5 Old 12-11-2018, 03:14 PM Thread Starter
Thanks. I put it in the shop. I'll share the results.
BC
post #4 of 5 Old 12-16-2018, 03:06 AM Thread Starter
UPDATE:
The problem has been taken care of by Eurocar-Werk in Houston.
The clock-spring was replaced.
Naed likes this.
post #5 of 5 Old 12-16-2018, 07:54 AM
Thanks for your update! The clock-spring can indeed wear out after 13 years of service
StefVan is offline
