F430 Error code P1021 and P1059 - Ferrari Life
post #1 of 9 Old 10-02-2017, 07:45 AM Thread Starter
johan6504's Avatar
Ferrari Life Posts: 230
My 430 Scuderia is in for 30000Km service and everything looks pretty good...
The car is however throwing two codes, that we cant seem to get rid of.
It is P1021 and P1059. Has anyone else encountered those codes before?
Any clue to what could cause this?
Ferrari 430 Scuderia 2008/12
(Ferrari 355 GTS F1 -99)
(Ferrari 355 GTS F1 -98)
johan6504 is offline
post #2 of 9 Old 10-02-2017, 08:21 AM
Ferrari Life Posts: 2,364
In which ECUs are these P codes stored? U & C codes are usually the Suspension ECU (NCS). When you're driving, does these codes disappear?
StefVan is offline
post #3 of 9 Old 10-02-2017, 08:27 AM Thread Starter
johan6504's Avatar
They are stored in the engine.
post #4 of 9 Old 10-02-2017, 11:58 AM
Ok, thanks. And while you're driving, your passenger reset the codes with your tool, does they appear again?
StefVan is offline
post #5 of 9 Old 10-02-2017, 12:21 PM Thread Starter
johan6504's Avatar
Dont think they tried it while driving, I will see if we can try that on Thursday. Any particular reason for resetting while driving? Any clue to what sensor/s is involved here?
post #6 of 9 Old 10-02-2017, 12:34 PM Thread Starter
johan6504's Avatar
Not sure it has anything to with the error, but since I have a MOTON chassi. There is an EDC-cancellation kit installed to kille the damper error light.
post #7 of 9 Old 10-02-2017, 01:38 PM
If you really had a wheel speed sensor (ABS) error, you would have had also several ABS and E-DIFF error codes too. Your Motronic ECU's are saying that they couldn't get the wheel speed data over the CAN bus. This can be a simple error without any consequences when your car simply stands still. Although, when the car is moving, these errors shouldn't appear and you should be able to display the real wheel speed with the diagnostic tool.
StefVan is offline
post #8 of 9 Old 10-02-2017, 11:19 PM Thread Starter
johan6504's Avatar
If you really had a wheel speed sensor (ABS) error, you would have had also several ABS and E-DIFF error codes too. Your Motronic ECU's are saying that they could get the wheel speed data over the CAN bus. This can be a simple error without any consequences when your car simply stands still. Although, when the car is moving, these errors shouldn't appear and you should be able to display the real wheel speed with the diagnostic tool.
Thanks, I get it :-)
Still wonder if it could be related to the EDC-cancellation kit...
post #9 of 9 Old 12-17-2019, 07:24 AM
Ferrari Life Posts: 1
Dear johan6504,
Now I have the same problem with my F430 F1 Spider, do you have find a solution?
Thank you!
Marcello
gmax66 is offline
