360 Removing A/C Vents from a 360 dash - Ferrari Life
 1Likes
  • 1 Post By SoftwareDrone
post #1 of 14 Old 11-07-2015, 08:54 PM Thread Starter
Ferrari Life Posts: 90
I have searched and searched on this topic. Nothing here. People have posted in other forums, but their stories vary wildly. I have managed to pop the outer ring off but cannot remove the vent assembly. I don't buy the "it pulls right out" story as I have pulled and pulled on it (with tools) and it does not budge. I read about inserting thin screwdrivers into the "3 and 9 O'clock positions" but there is nothing at the 3 and 9 O'clock positions. There are slots at the 8:45 and 3:15 positions, but I can feel nothing back there, no tabs to release, anything.
Any help would be appreciated.
SoftwareDrone is offline
post #2 of 14 Old 11-09-2015, 10:17 AM Thread Starter
I received the definitive word last night from someone who had to remove all of the vents from a 360 dash.
If I see any interest in this thread I will keep updating.
post #3 of 14 Old 11-09-2015, 10:54 AM
netman's Avatar
Ferrari Life Posts: 226
Use painters tape to protect the dash leather. Get yourself some plastic pry tools and reach behind the black plastic lip of the vent with the pry tools
See link below for more details
http://cdn.macarbon.com/install_guid...on_install.pdf
netman is offline
post #4 of 14 Old 11-09-2015, 02:58 PM Thread Starter
From that website:
"If the ring is loose or the air vent particularly tight, the ring itself may pop off. If that happens, you'll need to pull the rest of the vent body out."
however, they give NO CLUE as to how to actually do that.
post #5 of 14 Old 11-09-2015, 03:02 PM
Ferrari Life Posts: 1,875
Mike,
Cut a piece of thin rubber (say 1/16 thick rubber) and cut it so it will fit between the vent slats. Then use needle nose pliers to grab a hold of the vent slats (being protected by the rubber) and pull. That should get them free.
post #6 of 14 Old 11-09-2015, 03:05 PM Thread Starter
Mike,
I actually did one better. I inserted thin allen wrenches, bent side first, into the openings at the 8:45 and 3:15 positions, then turned as to create "hooks". Then I grabbed each of the two allen wrenches with normal sized pliers and pulled as hard as I could - nothing moved.
There are clips inside that no one is talking about that must be released.
post #7 of 14 Old 11-09-2015, 03:06 PM Thread Starter
Thank you guys for your input!! :-)
post #8 of 14 Old 11-16-2015, 08:32 AM
Ferrari Life Posts: 16
I am interested. So, what is the definitive answer?
curtisc63 is offline
post #9 of 14 Old 11-17-2015, 03:03 PM Thread Starter
You need a special tool. Essentially a "hook". It must be at least six inches long, have a handle on one end, a thin, straight steel rod with a hook on the other end. You must carefully reach down into the vent approximately four inches and hook the very back end of the vent. Reach down near the outer edge of the inside at the 3 O'clock position (not near the center) because you are hooking on the outer edge of the vent at the rear. You need to pull straight at you with a considerable amount of force. Do this at the 9 O'clock position, then at the 3 O'clock position, alternatively. Ideally you would have two similar tools and can pull from both the 9 and 3 O'clock positions simultaneously.
The dealer used a tool that looks almost exactly like this:
Anglers' Choice T-Bar Hook Remover | Academy
He popped one of my vents out, handed me the tool and I popped another one of my vents out on my own, in about 10 seconds.
Removing the outer ring first gets you nothing because if you try to hook into the access holes behind it, you are essentially also hooking behind the steel ring behind the vent that is permanently attached to the dash. You'll pull the dash out before you pull the vent out if you try this. Removing the inner vent assembly does you no good either because you can easily get the tool past the vents and hook into the very back end of the vent without removing the inner assembly. Under no circumstances should you pull against the back of the inner vent slats themselves as they are way too delicate for the force needed to remove the vent. The "tabs" that others refer to are at the 2, 5, 7 and 10 O'clock positions and while they keep the vent from popping out on its own, do not hold the vent in such that they will break if you try to pull the vent out without depressing these tabs, so don't worry about these.
So, to review, you need to hook behind the very back of the vent (the vent is 4" deep so you need a tool at least 6" long) and pull straight out toward you.
graemet likes this.
post #10 of 14 Old 11-18-2015, 05:39 AM
post #11 of 14 Old 11-23-2015, 12:55 PM
Thanks for the detailed information. If your vents are out of the car and available, could you take a couple pics of them so we can see what you described?
CC
post #12 of 14 Old 11-26-2015, 11:23 AM Thread Starter
CC
I'll do you one better my friend! :-)
I am making a video that details everything. Stay tuned...
post #13 of 14 Old 11-27-2015, 12:15 PM Thread Starter
As promised. :-)
post #14 of 14 Old 11-30-2015, 09:13 AM
Loved it! Thanks!
