F430 AIRBAG light - Ferrari Life
post #1 of 5 Old 06-30-2015, 11:21 AM Thread Starter
Ferrari Life Posts: 63
AIRBAG light
Hi everybody-
Just thought I'd post my problem here and see if I can get any good info.
As some of you may know, part of my project involved swapping out my interior. My new dash came with it's airbag ....and I just plugged it in. My steering wheel airbag was dyed black, and went right back in. The airbag light came on as soon as I fired the car up for the first time after the project ended. Thinking it might be a faulty passenger side airbag, I swapped back my original one...still have the light. I removed the steering wheel airbag to see if I might've forgotten to plug it back in....I didn't. But I jiggled the connector just for the hell of it. Still have the light. Power is always shut off at the main cutoff switch prior to working on the car.
-would an SD3 be able to diagnose where my problem might be?
-could there be another connector further under the dash that I should look for? I disconnected and color coded every connector when I removed the old dash and put in the new one, and I'm fairly positive I didn't forget to connect any. Everything else works fine.
Does anybody have any advice?
Thanks!
-George :-)
George in NH is offline
post #2 of 5 Old 06-30-2015, 12:59 PM
Ferrari Life Posts: 966
SD-2 maybe, SD-3 definitely required...After a system check has been done, components verified to be functioning properly, the light could then (presuming no significant issues) be reset.
All air bag wiring is bright yellow, FWIW.
post #3 of 5 Old 06-30-2015, 01:33 PM Thread Starter
Hi David-
Awesome coincidence that you replied!!....I've been planning to call you and introduce myself and see if you wanted a new customer :-)
Part of my research prior to buying my car ('07 F430 w/manual gearbox) was to find a highly respected shop to take care of it...and you're the guy I discovered. Knowing that you were relatively close made me feel comfortable buying such an expensive (for me) and complicated car.
Anyway, I'll give you a call tomorrow to talk about the airbag light, and something else I'd like done to the car. I'll call in the morning, but if there's a specific time you'd rather talk, please let me know. And, oh yeah, thanks for replying!
Your new customer,
George :-)
post #4 of 5 Old 06-30-2015, 05:57 PM
Hi George,
Thanks for the compliments. As you know, these are not the easiest nor most cooperative cars to service, at times. A 430 with a standard is a pretty rare bird. I've got a client in Maine with one. In my opinion, the six speed is a far better way to go. Although the F1 is a pretty neat experience, the cost of maintenance and potential repairs can be considerable in the event of a failure.
On your air bag issue; Interesting timing, as I had a 360 in a few weeks ago with an unexpected air bag warning light. Give me a call anytime after 9:00am.
Best,
David
post #5 of 5 Old 07-01-2015, 04:07 AM Thread Starter
Hi David,
I also think the F1 is a cool experience...for a one time drive. For me though, there was never any question of what I wanted. In 35 years years of driving, and dozens of cars, only 1 has been an automatic. Just personal preference, don't mean to upset any F1 fans that might be reading this ;-)
OK, it's time for breakfast! I'll call you later this morning...
Thanks again :-)
-George
