360 360 Roll Over Valve. - Ferrari Life
post #1 of 2 Old 06-28-2015, 11:51 AM Thread Starter
Ferrari Life Posts: 1
Gents, I have a 2004 spider that is giving me the small evap leak code. Since I see it's been an issue I ordered the roll over valve. Where is valve located? What do I need to remove to access it? Thanks in advance!
Any others I should replace while I'm doing the roll over valve?
Blentz33 is offline
post #2 of 2 Old 06-30-2015, 12:14 PM
JaguarDriver's Avatar
Ferrari Life Posts: 9
The 2004 Spider has 4 rollover valves. Although it is possible to access without removing the top, it is difficult. They are under the convertible top retaining tray which needs to be lifted to access them. You cannot move it up very far with the top in place. Best to do a leak test and find which one is leaking. There are 4 different ones so 4 different part numbers. Since you ordered the part, I assume you know which one is leaking. Not hard to replace once you can access it.
Dick Maury, Rebuild Manager-Coventry West, Past JCNA President
JaguarDriver is offline
