360 Clutch replacement without SD2 - Ferrari Life
post #1 of 6 Old 06-05-2015, 02:08 PM Thread Starter
Hey everyone, I'm new here and I'm looking for some advice.
I have a 2002 360 F1 and the car just had its major done at a Ferrari Dealership, at the time it was noted that my clutch needed to be replaced as it was at 97% wear. Unfortunately I didn't have the funds to get it done so i just got the major finished and drove the car home (3 hours away). Anyways, 2 months later and I'm getting the clutch done at an independent here in town that doesn't have an SD2. I want to take the car back to ferrari to get the PIS adjusted and the clutch parameters back to normal, but theres no guarantee that the dealership will do it because they never did the work.
Any recommendations/input or help would be greatly appreciated. Thanks
russomanno is offline
post #2 of 6 Old 06-05-2015, 03:21 PM
Ferrari Life Posts: 966
97% worn...and you were able to still drive the car. I suspect that wear number is erroneous.
Regardless, save yourself much aggravation and future clutch life; bring it to someone with an SD-2 to begin with or back to the dealer. It will cost you much less in the long run.
post #3 of 6 Old 06-05-2015, 03:30 PM Thread Starter
Too late, the car is already taken apart
post #4 of 6 Old 06-06-2015, 08:41 PM
Ingenere's Avatar
Ferrari Life Posts: 104
There is a 'back door' to set the PIS without the SD2 that I learned from a Ferrari factory tech.
Ciao
Dino
TR, F40, Mondialt cab, 308QV, 348 Challenge, CS
Ingenere is offline
post #5 of 6 Old 06-07-2015, 08:11 AM
netman's Avatar
Ferrari Life Posts: 226
Please do share how to set the PIS without an SD2
netman is offline
post #6 of 6 Old 06-07-2015, 01:21 PM
And bleeding the clutch annular bearing...? (I guess you could disconnect the pump from the rest of the electrical system and power it up to bleed. A pretty hack solution, but anything is possible,)
