360 Battery Fitment Issue - Ferrari Life
post #1 of 10 Old 05-08-2015, 10:24 AM Thread Starter
ScuderiaAudio's Avatar
Ferrari Life Posts: 145
Years ago, I replaced the OEM Fiamm battery with an Interstate equivalent. Now it's time once again to replace the battery. Trouble is, I cannot find a replacement that will fit. All of the documentation I have read so far indicates that the "Group Size" is group 34. However, all group 34 batteries are at least 7" tall. The Interstate battery currently in my car is 6" tall in the front (where the hold down bracket is placed) just like the Fiamm. Of course, my current battery is no longer made, and the replacement batteries are all group 34.
All you folks out there with Group 34 batteries in your car, how do you get them to work? I wouldn't even be able to slide a 7" battery underneath the support bracket, let alone get the hold down strap to work (???).
ScuderiaAudio is offline
post #2 of 10 Old 05-08-2015, 11:12 AM
Ferrari Life Posts: 11,872
Interstate MTP-91/H6 is 6.88" tall atop the terminals. Here is the FIAMM battery recommendations and sizes.
post #3 of 10 Old 05-08-2015, 11:55 AM Thread Starter
Thank you for the info.
If you look at a picture of the Fiamm battery along with the dimensions, you will see that the front edge of the battery is about one inch shorter than the rest of the battery. So, although the maximum height of the battery is almost 7" (like every other group 34 battery), the front edge is around 6" tall (which is why it fits).
post #4 of 10 Old 05-08-2015, 12:16 PM
Ferrari Life Posts: 18
Give Odyssey battery some consideration. Smaller and lighter. Fitted to my 360 and given great service. Try it, you'll like it!
anconbrat is offline
post #5 of 10 Old 05-08-2015, 12:28 PM
The Odysseys are actually heavier than traditional lead acid battery if you get their recommended AGM model for Ferraris. The 925 some owners fit is actually undersized for the application.
post #6 of 10 Old 05-08-2015, 02:36 PM Thread Starter
With all the folks asserting that a 190mm tall battery will fit without modifications, I went ahead and purchased an Optima red top 34R.
IT DOES NOT FIT.
I will need to either:
a) Cut down the tie down posts, screw in standoffs and studs to increase the length by one inch.
b) Find longer tie down posts.
Additionally, you cannot purchase yellow top (deep cycle) Optima batteries with reverse posts.
post #7 of 10 Old 05-08-2015, 04:16 PM Thread Starter
Okay, so I purchased longer rods, test fit them, marked and shorted them to the exact size, and the battery barely fits. But...
Now my radiator fans won't kick on when needed. The temperature almost got into the orange zone, scared the crap out of me. Does anyone know off hand where those fuses are?
post #8 of 10 Old 05-08-2015, 05:27 PM Thread Starter
I searched and searched through the 360 pdf manuals and found the 40A maxi fuse for the fans. The fuse is okay (checked it with a meter). I looked in the overflow coolant tank and found a significant amount of oil in the coolant. This will be the second time now that the fantastically engineered (yeah right) intercooler has failed on me. So this trip to the shop will entail the gearbox removal, rebuild and reinstall, exhaust manifolds replacement and intercooler replacement. Hopefully the fans will work after this.
post #9 of 10 Old 05-11-2015, 07:12 AM
Ferrari Life Posts: 20
OUCH!!! Sure wish it was just a fuse.
ncjetskier is offline
post #10 of 10 Old 05-11-2015, 03:29 PM
Ferrari Life Posts: 9,567
wetpet is offline
