F430 Ride Height - Ferrari Life
post #1 of 3 Old 09-07-2014, 02:07 PM Thread Starter
Ferrari Life Posts: 80
Ride Height
While doing some work on the car I noticed I had more room to place the jack on the right side than I did the left side. I measured from the floor to the top of the wheel well and sure enough the right side was 1/2" higher. Both tires are the same size and have the same pressure, although due to a curb that jumped out the right side is newer. The left side tire has plenty of tread.
Could that big a difference be caused by more wear on the left side tire? Should I be concerned about the difference and/or adjust the suspension.
Thanks!
Rich
RCBFL is offline
post #2 of 3 Old 09-07-2014, 07:10 PM
Ferrari Life Posts: 11,859
Rich- Personally I would have ride height and suspension alignment adjusted by an expert with a supply of camber shims. Ride height is easily adjusted with a spring compressor and ring nut wrench, but camber and toe will need to be adjusted afterwards.
post #3 of 3 Old 09-07-2014, 08:21 PM Thread Starter
Thanks Taz.
Rich
RCBFL is offline
