360 Steering Column Covers Removal - Ferrari Life
post #1 of 4 Old 07-13-2014, 07:26 AM Thread Starter
Ferrari Life Posts: 50
Does anyone know if it is possible to remove the sterring column covers without removing the steering wheel? My headlights are only working intermittently and I'm down to a loose connector at the switch or the switch itself.
Thanks,
Jeff
JeffWilliams is offline
post #2 of 4 Old 07-13-2014, 10:40 AM
netman's Avatar
Ferrari Life Posts: 226
Yes you can. IF your car is an F1 its is best to remove shift paddles and I recommend removing the gauge cluster as well. There are some Phillip head screws that need to be removed from the underside, then loosen the steering column position lever to lift the column to its highest and most extended position. At this point you should be able to use a plastic putty spoon to split the halves and remove the lower. Now again use the steering column potion lever to raise the wheel to its lowest point and lift the top half off.
netman is offline
post #3 of 4 Old 07-13-2014, 03:17 PM Thread Starter
Thanks, netman. Sounds straight forward enough.
Cheers,
Jeff
post #4 of 4 Old 07-14-2014, 03:53 AM
Ferrari Life Posts: 33
Actually the column covers have to be removed in order to take out the gauge cluster. You have to be very careful removing the covers as the plastic pieces can break off very easily. The top cover is the most difficult because you have to wrangle it over the ignition lock barrel. Just take your time and be patient.
Alan
English Rebel is offline
