F430 help 430 indicators not working - Ferrari Life
post #1 of 7 Old 05-10-2014, 09:21 AM Thread Starter
had car out today and indicators are not working
checked fuses under the bonnet cant see any blown but not sure if looking at correct ones!
hazards work but no indicators left or right
any ideas????
430sh is offline
post #2 of 7 Old 05-10-2014, 02:31 PM
Ferrari Life Posts: 11,858
Welcome to Ferrari Life. Turn signal indicators?
post #3 of 7 Old 05-10-2014, 06:28 PM
netman's Avatar
Ferrari Life Posts: 226
Check the flasher relay.
netman is offline
post #4 of 7 Old 05-11-2014, 03:37 AM
Ferrari Life Posts: 2,340
Welcome the FerrariLife The F430 has a specific ECU to manage the turn signal lights. The ECU is located under the dashboard at the passenger side. It is protected by a 15 Amp fuse AF17. This fuse is located in the front luggage compartment as show on this picture.
Make sure this fuse is fine which should be if your hazards are still working, but better check it.
Any chance you changed something on your turn signal lights? Maybe LEDs? Some cheap LED's WILL break this ECU on the F430, I can unfortunately warranty that. This ECU is very different from the usual flasher relay as it contains several fragile IC's. I just hope this isn't your case.
The other thing you can also check is the steering column switch. There are 4 large connectors and 2 are partly used for the turn signal lights. Make sure that these connectors are correctly connected.
Let us know how it goes
post #5 of 7 Old 05-11-2014, 04:24 AM Thread Starter
thanks for info! checked fuse its fine, nothing changed bulb wise, it worked on the way to the shop just not on eay home, I did notice the radio had not gone off when I returned to the car?
if press the hazards can hear the relay clicking behind glove box
430sh is offline
post #6 of 7 Old 05-11-2014, 11:45 AM
Any chance your car has been jump started? There is indeed a small relay in the ECU, that's what you hear. You're saying that the hazards do work normally?
post #7 of 7 Old 05-12-2014, 11:50 AM
Ferrari Life Posts: 6,196
try swapping relays
