360 ( PIC ) LED Front Parking Lights installed - Ferrari Life
post #1 of 20 Old 04-25-2014, 09:04 PM Thread Starter
Jimmy540i.com's Avatar
Ferrari Life Posts: 211
Huge Difference vs the old IMHO. Feels like the car is 10 years younger lol...
Here's a before & after picture:
Feel free to check out rest of this easy mod here:
LED PARKING LIGHTS for FERRARI 360 MODENA / 360 SPIDER @ (www.Jimmy540i.com)
Feedback are more than welcome :-)
Jimmy
Jimmy540i.com is offline
post #2 of 20 Old 04-29-2014, 12:46 PM Thread Starter
One more fine picture, cheers :-)
post #3 of 20 Old 04-29-2014, 01:03 PM
BluNart's Avatar
Ferrari Life Posts: 479
Jimmy, What a difference and is something I should also do. What LED did you replace it with & did you need to flip the battery switch for ECU protection?
Other: 2004 C5 Coupe
BluNart is offline
post #4 of 20 Old 04-29-2014, 08:11 PM
netman's Avatar
Ferrari Life Posts: 226
No need to flip the battery switch. Best to make the change with the lights and ignition in the off position.
netman is offline
post #5 of 20 Old 04-29-2014, 08:21 PM Thread Starter
Hey BluNart. The installation was surprisingly easy. I did shut down the battery during the process (though you don't really have to). The parking light bulb (Dipper) is inside your front fender, simply turn your wheel inwards and you can access to the cover panel, remove the panel; locate/remove the bulb, then a straight bulb swap and you are good to go.
You can also look into your owner's manual. I received these 2 LED bulbs from a company from Italy, they saw my website and sent me these samples just to try it out, and I am happy with the color / glare (Bright white with a tiny hint of blue). You might be able to find similar LED bulbs in the US. Just make sure the color is what you like and the right wattage.
Here's what the bulbs look like (OEM vs LED):
This IS a MUST-DO mod for any 360 in my opinion. I also LEDed my Dome Lights & License Plate Lights. Day & Night difference. Now still waiting for LED reverse bulbs, I will post them here later on.
Cheers!
post #6 of 20 Old 05-02-2014, 12:47 PM Thread Starter
BluNart, Here's what I took off the owner's manual. Parking Lights is #3. cheers!
post #7 of 20 Old 05-02-2014, 01:02 PM
BluNart's Avatar
Thanks! I had the 'dipper' in my hand last year to size it for a replacement but never swapped as I couldn't find a local supplier for the LED to compare. I'll have to search & order on-line as the yellowing is not preferred; any posts here or on another site that have the same or comparable bulb are welcomed...
BluNart is offline
post #8 of 20 Old 05-02-2014, 11:05 PM Thread Starter
The LED manufacture might have sent me an extra set, let me look for it. If I can find it, I will send them to you
post #9 of 20 Old 05-05-2014, 05:40 AM
BluNart's Avatar
Thanks Jimmy! If their good in your 360 they'll work out great in mine. The before/after photos show how much a change this simple mod makes to the 360 appearance.
BluNart is offline
post #10 of 20 Old 05-05-2014, 03:30 PM
netman's Avatar
Take note. LED bulbs are polarity sensitive. If it does not work on the first try. Remove the bulb and position in the opposite direction.
netman is offline
post #11 of 20 Old 05-06-2014, 08:08 PM Thread Starter
ditto
Blu, I found the extra set of LEDs, I tired to PM you via this forum but somehow I can't get the PM to work. Can you PM me your e-mail (hope it works on your end) or you can shoot me 1 to: [email protected]
Cheers and I am sure you will love it on your 360 as much as I do.
post #12 of 20 Old 05-07-2014, 06:36 AM
BluNart's Avatar
Jimmie you rock! PM sent.
Can't wait to see the result & will share before & after photos.
BluNart is offline
post #13 of 20 Old 07-09-2014, 11:26 AM Thread Starter
u bet, let me know how that worked out for u
post #14 of 20 Old 07-10-2014, 05:03 AM
Ferrari Life Posts: 33
I believe that these are the bulbs for the front marker lights. BTW the manual says that the bulb holder pulls out -- it doesn't -- it needs a quarter turn first.
Alan
T10 2 10 SMD 168 194 1206 W5W Hyper White LED Light Lamp Bulbs Canbus Error Free | eBay
English Rebel is offline
post #15 of 20 Old 07-15-2014, 08:47 PM
Ferrari Life Posts: 5
I replaced my LED parking lights this evening and I must say it is a huge improvement. It really updates the car giving it a more modern feel. It took all of 20 minutes working quite slow. I only ran into one problem, when this huge beetle flew into my garage and landed right where I was working. It is about as big as my hand and yes it fly's. It will make you run for your life and scream like a girl.
Thanks English Rebel for the ebay link. I bought them and they worked out quite well.
torresmd is offline
post #16 of 20 Old 07-15-2014, 08:48 PM
Sorry for the upside down pics. Not sure what happened.
torresmd is offline
post #17 of 20 Old 08-16-2014, 12:49 PM Thread Starter
fixed for ya.. nice car!
post #18 of 20 Old 08-18-2014, 07:19 AM
Thank You!!
torresmd is offline
post #19 of 20 Old 01-28-2015, 11:27 AM
BluNart's Avatar
Jimmy,
I'm embarrassed how long it took for me to make the change after you generously provided the bulbs; my apology for also not posting sooner. It's obvious which bulb is changed in the photo and wow does it remove the yellow tint of the OEM bulbs and 'modernizes' the front parking lights. Such a simple change and what a difference.
Now only if a LED bulb had some magic to clean up the foggy headlamps...
Thanks again Jimmy!
BluNart is offline
post #20 of 20 Old 02-27-2015, 11:11 PM Thread Starter
Jimmy,
Thanks again Jimmy!
You bet! The LED looks GREAT!!
I love the color of your car man!!!!
