F430 F1 Pump spare-quick opinion - Ferrari Life
post #1 of 7 Old 03-11-2014, 08:25 PM Thread Starter
chenglo1's Avatar
Ferrari Life Posts: 531
Guys,
my VIN is 149600's. Will this F1 pump fit my build or did they move to a better more robust version? i am about to open up my panel to compare but wont get around to it until tomrw. My thought is to have a spare JUST IN CASE i need to shell out 2500 someday for the part. i watched a youtube video and looks pretty straightforward to replace. Any input appreciated as always. But hey, dont go out and buy it from under me! My independent consult already said go ahead and buy it for that price!
https://www.ferrarichat.com/forum/fe...-f430-new.html
chenglo1 is offline
post #2 of 7 Old 03-11-2014, 08:35 PM
The assembly number is different than the VIN number. If you open the engine bay lid and look straight down, to your left you will see the "Assembly Number" tag.
There have also been a couple threads about how "easy" it is to swap the pump. Literally physically replacing the pump is straightforward. Flushing, bleeding & calibrating the F1 system is a whole other process which requires a Ferrari capable diagnostic computer. It is wise to not short cut the pump replacement when the time comes and have the entire procedure carried out.
post #3 of 7 Old 03-11-2014, 08:41 PM Thread Starter
chenglo1's Avatar
THx Josh. any opinions? i figured for the price it is/was a no brainer if it truly is brand new and direct replacement.
chenglo1 is offline
post #4 of 7 Old 03-11-2014, 09:41 PM
Cheng, if your local mechanic is OK with installing that pump if you supply it, You're good to go. Assuming your car takes this style pump and not the other. Please check your Assy. number tag and verify first.
post #5 of 7 Old 03-11-2014, 09:54 PM
Ferrari Life Posts: 11,859
Cheng- You have the newer pump so do not really need a spare. On F1 cars, the pump was upgraded at AN 61589, which correlates to a serial number in the 1439xx-1441xx serial number range. So save your money.
post #6 of 7 Old 03-11-2014, 11:10 PM Thread Starter
chenglo1's Avatar
whew!
Thanks Terry. Almost an excuse to pull the coves off! DId i mention that we made it above freezing 4-5 days in a row???
chenglo1 is offline
post #7 of 7 Old 03-12-2014, 10:00 AM
Cheng- With the Jet Stream patterns, we did not even have a real winter here in the high desert. Only snowed twice and that did not even bother the roads too much. Everybody north or east of here got pounded, though.
