F430 Steering wheel removal - Ferrari Life
post #1 of 7 Old 01-31-2014, 10:27 PM Thread Starter
Ferrari Life Posts: 7
Does anyone know what tool is used to remove the center retaining nut to remove the steering wheel. Would I just use a large socket? Any idea what size I would use? Just trying to line up the tools before I get started. Thanks.
guidwire is offline
post #2 of 7 Old 02-01-2014, 08:40 PM
Here is what the workshop manual says. Looks like it is just a big hex nut once the plastic cover is removed.. I have no idea on the size. You can always measure it. Here is a blow up of the nut once removed.
post #3 of 7 Old 02-02-2014, 10:23 PM Thread Starter
Thanks Taz. It turned out to be 24 mm.
guidwire is offline
post #4 of 7 Old 04-30-2014, 10:24 AM
Ferrari Life Posts: 3
Were you able to reuse the wheel retaining nut? The workshop manual suggests using a new nut. How easy was it to install and reinstall the wheel?
Thanks!
icoburn is offline
post #5 of 7 Old 04-30-2014, 11:05 PM Thread Starter
It was pretty easy to do once I had the right tools. The nut is on pretty tight. I had to use a big breaker bar to loosen it. I was able to reuse the nut which seemed fine. I was able to torque it to the recommended spec. So far so good.
guidwire is offline
post #6 of 7 Old 05-05-2014, 06:22 AM
Thanks!
icoburn is offline
post #7 of 7 Old 05-09-2015, 11:15 AM
torque
Hi, what is the recommended torque for the steering wheel, I believe I read 50 Nm somewhere but I am not sure. Thanks for answering ...
odf911 is offline
