360 Gearbox Cost - Ferrari Life
post #1 of 3 Old 09-26-2013, 04:28 PM Thread Starter
Ferrari Life Posts: 7
Gearbox Cost
Can any tell me how much a gearbox for a F360 will cost if it needs to be replaced and how often do you have to do such a thing on average?------Thanks
JPEEPS is offline
post #2 of 3 Old 09-26-2013, 10:05 PM
Ferrari Life Posts: 11,858
Are you worried about the clutch or the gearbox? The gearbox should last through your ownership unless it is driven a whole lot of miles every year. Same for the engine.
Clutch life is determined by driver technique and on what type of roads she is driven. For F1, anywhere from 15K-60K miles and a bit longer for the three pedal versions for most drivers.
post #3 of 3 Old 09-26-2013, 11:51 PM
sergio360's Avatar
Ferrari Life Posts: 68
From my experience,it all depends in the driving style and/or any problems that can occur through the car's life.For example,if your garage exit is inclined and the clutch is not warm yet,you will slip it to get out and finally reduce its life.Because i have this problem with the garage exit,i try to warm the clutch inside the garage by doing some maneuvers inside and after that(you can feel it when it starts to bite properly)i exit.
sergio360 is offline
