F430 Convertible Roof Frame Cracks. :-( - Ferrari Life
post #1 of 11 Old 06-24-2013, 12:03 PM Thread Starter
Ferrari Life Posts: 31
Bad Times
The inner Plastic/Composite panel on the Passenger side of my convertible roof has cracked and split. Has anybody else encountered this problem and do I need an entirely new roof?
Kindest Regards
CR
captain_rossco is offline
post #2 of 11 Old 06-25-2013, 03:56 AM Thread Starter
post #3 of 11 Old 06-25-2013, 04:15 AM
Ferrari Life Posts: 17
roof
how did that happen? just from opening and closing? I have these parts if needed
ovducati7 is offline
post #4 of 11 Old 06-25-2013, 04:27 AM
roof
Originally Posted by captain_rossco View Post
Bad Times
Kindest Regards
CR
looking from the parts book, it seems you can not buy only this piece. very weird. sent you a PM if you need anything. cheers.
post #5 of 11 Old 06-25-2013, 04:32 AM Thread Starter
Replied! Thank you so much!
post #6 of 11 Old 06-25-2013, 08:26 AM Thread Starter
Ferrari now stock the part as a standalone. Phew
615.00 later!
post #7 of 11 Old 07-15-2013, 03:02 PM
This part should be sent out from ferrari to all spiders as its a weak part..been looking for a used part but now thanks to your post i dont have to look further, thanks for sharing this!
Kenman is offline
post #8 of 11 Old 07-15-2013, 03:49 PM
champagne612's Avatar
Ferrari Life Posts: 10,022
I have seen two others - very common to fail.
Mine froze the other day but after restarting the car all was well.
champagne612 is offline
post #9 of 11 Old 07-18-2013, 02:19 AM Thread Starter
No problems folks,
please be aware, this is a more recent exploded diagram, some independents are not aware of this parts existence as a stand alone part.
Enjoy!
Regards
CR
post #10 of 11 Old 08-04-2013, 06:21 PM
Ferrari Life Posts: 4
I believe this part is broken when the center bow of the top is not pulled back on retraction. If you partially retract the top, you can look between the headliner and the top and see a strip of cloth that has detached from the bow. Compare the two sides as the bow seems to move independent on each side. If the bow does not swing back on top retraction then it will interfere with the top frame and cause this section to break. I think the section is magnesium and could be welded under the proper conditions.
Does anyone have a part number for this. Ask me why I need it.
Stout is offline
post #11 of 11 Old 08-05-2013, 05:50 AM
CarlosR's Avatar
Ferrari Life Posts: 47
I cant really explain what happened, but going on a ledge somewhat...
If the F430 uses dual motors to lower the top, then keeping them in synchro is an absolute must. Otherwise one side of the top lowers faster than the other and bam.
I had this happen in an older Porsche I own, and as a result the frame cracked similarly.
CarlosR is offline
