F430 Few problems with my 430 + Pics - Ferrari Life
post #1 of 6 Old 06-17-2013, 09:27 PM Thread Starter
dschlaegel's Avatar
Ferrari Life Posts: 6
I have been having a few problems with my 430. One that has always been there since I got it I have noticed allot of people have the same issue. Sometimes while shifting it will go into neutral or just skip from like 2 second to 5th. Sometime, I will even get stuck in neutral and cant go into first. I get the amber slow down at the same time. Seems to be worse on hotter days for some reason. Anyway, now today for some reason I noticed I smelled coolant, and I see it coming out of my car. Noticed it was running pretty hot. Not even a hot day.
My car has had some Novitec upgrades, including cat bypass. So I know that is causing some issues, most likely thinking its overheating even though I don't even had cats.
I am thinking maybe all the issues are connected but not sure.
Ok here is the weird one though. I noticed some weird residue on one side of my engine. Looks almost like a buildup of fiberglass?
Other side is perfectly clean, so is entire engine bay other than that one spot.
Anyway, at the moment I am charging my battery all night. I will turn it off in the morning for 30 minutes and hopefully restart the system after I put in some new coolant. In case my cats or something else just caused some issues while I was racing my friends GTR the other day.
I also noticed something unplugged, im thinking its something for the cat bypass, here is a pic.
Anyone have any clues about any of my issues or pics? Thanks in advance for the help.
dschlaegel is offline
post #2 of 6 Old 06-18-2013, 12:59 PM
Ferrari Life Posts: 11,858
Looks like header or cat insulation. You still have precats in the headers, correct? Could be a cracked header.
post #3 of 6 Old 06-18-2013, 04:11 PM Thread Starter
dschlaegel's Avatar
Ahh, I will have to check that out. Wonder if that has anything to do with the heating or gear skipping (due to extra heat in the engine bay)
post #4 of 6 Old 06-24-2013, 01:13 AM
Ferrari Life Posts: 31
People have spoken of white residue when the headers crack, this may well be the very same.
CR
captain_rossco is offline
post #5 of 6 Old 06-24-2013, 02:40 PM
David- Probably does not have much to do with skipping gears. You need to see someone with an SD3 to sort that problem. Many possible causes.
post #6 of 6 Old 06-24-2013, 04:37 PM
Ferrari Life Posts: 768
Hi guys , the headers are broken. you have to smoke the headers with a smoke machine . This is a very common problem. There is a emission warranty on headers. I just had three cars down in the last 4 weeks.
Alex.
ALEX A is offline
