360 Soft brake pedal after fluid change - Ferrari Life
post #1 of 6 Old 04-13-2013, 10:15 AM Thread Starter
Ferrari Life Posts: 53
Had local shop replace brake fluid with high performance fluid (higher boiling point) for my upcoming trip to the track. The result was a mushy pedal (longer travel to engage brakes). I immediately pointed it out and the owner road tested the car. He said the same thing happened on his 360, he bled the system multiple times and no change. His ultimate conclusion was that replacing the old fluid actually made the calipers work better (more fully release) and thus the increased travel.
The brakes do not pump up, so from another post, apparently that means there is no air in the system? The pedal does not slowly depress, so apparently no leak?
Not sure i trust the conclusion of the shop, so looking for input.
Thanks in advance for your help
Mortonl is offline
post #2 of 6 Old 04-13-2013, 10:17 AM
Ferrari Life Posts: 11,872
Morton- Bleed the master cylinder.
post #3 of 6 Old 04-13-2013, 12:03 PM
ferraricyprus's Avatar
Ferrari Life Posts: 121
Taz is spot on- bleed the master cylinder, make sure you do BOTH bleed points on it.
ferraricyprus is offline
post #4 of 6 Old 04-13-2013, 12:46 PM Thread Starter
Excellent, problem solved! FYI, for the newbie, I removed the drivers side panel and the panel at the back of the trunk compartment to access the bleeder nipples. Very easy.
As always, great advice!
Mortonl is offline
post #5 of 6 Old 04-13-2013, 12:55 PM
Morton- Every once in a while, I get lucky. Eddie actually knows what he is talking about.
post #6 of 6 Old 04-13-2013, 12:59 PM
Ferrari Life Posts: 768
Guys , when you do a brake flush or open the brake system for repairs. You need the Factory SD2 to bleed the system properly. You will never get all the air out. You may think it works properly but it's not.Every car that i have done , I need the SD2 to do it properly.
Good luck.
Alex.
ALEX A is offline
