360 Factory Speaker Wiring in Door Panel - Ferrari Life
post #1 of 5 Old 04-08-2013, 08:00 AM Thread Starter
bisel's Avatar
Ferrari Life Posts: 419
Hello,
I looked up the wiring diagram for the door speaker wiring and found the attached images. I am confused mapping the tweeter and woofer connections to the plug in the door jamb. According to the wiring diagram, both the tweeter and woofer are connected to the same plug pins. I would infer that the tweeter and woofer are getting the same signal. Is this in fact the case. That would tell me that the crossover for high / low is built in somehow in the speaker. Am I missing something?
Steve
bisel is offline
post #2 of 5 Old 04-08-2013, 08:32 PM
Ferrari Life Posts: 46
door spkr wiring
The door mid and tweeters do share the same wires through the door jamb....
Scott
sclja is offline
post #3 of 5 Old 04-08-2013, 08:35 PM
Yes the wires are shared...
Scott
sclja is offline
post #4 of 5 Old 03-16-2015, 08:57 PM
Ferrari Life Posts: 5
There may be crossover circuits. Some speakers that are co-axle or tri-axle separate frequency even when the same wires are attached to all three (Tri) and each speaker responds with its frequency range with a little or do duplication. Think of it as a co-axle speaker with the tweeter removed and the wires stretched to another mounting location.
Keith360 is offline
post #5 of 5 Old 03-16-2015, 10:57 PM Thread Starter
bisel's Avatar
The stock tweeter had a small crossover circuit built-in the back of the tweeter.
Regards,
bisel is offline
