360 Vapor Barrier in Front Luggage Compartment - Ferrari Life
post #1 of 6 Old 04-07-2013, 08:30 AM Thread Starter
bisel's Avatar
Ferrari Life Posts: 419
When I removed the rear fiber panel in the luggage panel, I discovered the white vapor barrier had a tear in it. Not a big deal, but I also needed to remove the vapor barrier so I can gain access to the firewall to route my new audio amplifier cables.
When replacing the vapor barrier, I could merely use some aluminum tape to seal the tear and tape down the edges ... or I could just replace the vapor barrier.
What is the Ferrari name for this vapor barrier? Where can i get this material? Or, can I just use a piece of home construction vapor barrier material like a piece of Tyvek or plastic sheeting.
Steve
bisel is offline
post #2 of 6 Old 04-07-2013, 12:16 PM
Ferrari Life Posts: 2,381
Steve, I don't think this vapor shield is available as a separate part. Dealers use large rolls of them and cut out the needed shape after a maintenance operation. I guess any similar vapor barrier product should do the job.
post #3 of 6 Old 04-07-2013, 07:50 PM
netman's Avatar
Ferrari Life Posts: 226
Contact Daniel at Ricambi. He sold me one for about 60.00
netman is offline
post #4 of 6 Old 04-08-2013, 09:37 AM
Ferrari Life Posts: 15
Ferrari Parts, Ferrari Accessories, and Ferrari Performance Products - Ricambi America, Inc.
Part number 66212900.
$69.52 from Ricambi.
27.17 from Eurospares.
Snowman is offline
post #5 of 6 Old 04-08-2013, 12:14 PM Thread Starter
bisel's Avatar
Thanks for the info. At $70 for a sheet of plastic foam whose purpose if merely to serve as a vapor barrier, I am thinking for far less money I can cut a piece of Tyvek vapor barrier and accomplish the same. Or perhaps a 7 mil thick piece of plastic sheeting. Anyone think this would not work? I don't want jeopardize the purpose of the barrier with a a home grown solution that may not work.
Steve
bisel is offline
post #6 of 6 Old 04-08-2013, 09:13 PM
As long as it keeps water spray out, you are good. I bought a new Ferrari one, and feel ripped off.....
Repair the one you have or use any other barrier material that will work.
And yes, it is needed, unless you never ever drive with water on the road.
Zcobra1 is offline
