F430 slow down - Ferrari Life
post #1 of 13 Old 04-06-2013, 09:58 AM Thread Starter
Ferrari Life Posts: 119
slow down
Just had a drive today around town and got to some traffic lights and a light came on saying slow down.car would not go into gear but temps all seemed OK.
Eventually I rev the engine and it then worked.
Any ideas lads.
gary.taylor17 is offline
post #2 of 13 Old 04-06-2013, 10:04 AM
Fiorano's Avatar
Ferrari Life Posts: 4,348
Slow down warning light has come on for the 360 on occasion (most recently at a track day) indicating that the cats are overheating. I'm guessing it's for similar reasons on a 430.
In my case looks like a fault O2 sensor is causing the problem.
Fiorano is offline
post #3 of 13 Old 04-06-2013, 10:07 AM
Ferrari Life Posts: 11,873
Garry- Like Barry said usually related to the cats and can be caused by a bad O2 sensor or a mixture problem that is dumping raw gas into the cat, where it burns. Can be serious and damage the cats, so something you want to get checked.
post #4 of 13 Old 04-06-2013, 11:07 AM Thread Starter
So its a case of telling the mechanic the same story. :-)
post #5 of 13 Old 04-06-2013, 11:52 AM
Garry- Affirmative and then hope it is something simple, like a faulty lambda sensor.
post #6 of 13 Old 04-06-2013, 11:55 AM
Fiorano's Avatar
Precisely what I am doing right now....
Fiorano is offline
post #7 of 13 Old 04-06-2013, 12:21 PM
Ferrari Life Posts: 132
Check my threads bud I had the same issue. It is not the cats, the slow down light was for later models with CAT issues not for the 430.
I had a air leak in my F1 system. I had this exact same error you are having.
F430, 458 Challenge, Ford GT, Gallardo, C63 Black,
PMCCHRIS is offline
post #8 of 13 Old 04-12-2013, 05:53 AM
ferraricyprus's Avatar
Ferrari Life Posts: 121
Any ideas lads.
Less likely to be cat related if the car wouldn't select gear. 430's also show a slow down warning if there is a lack of pressure in the F1 system, which could be several things, including a lazy pump,( if you have a mid-'06 or earlier they had issues with the carry over pump from the 360) e-diff solenoid or loose actuator bleed screw. In any case, you should get it checked out sooner rather than later.
ferraricyprus is offline
post #9 of 13 Old 04-12-2013, 01:11 PM
CAracer's Avatar
Ferrari Life Posts: 69
I had same issue here
I was told it was the cats. Which it wasn't. Turned out to be the E differential solenoid. About a $1000 dollar part plus labor. By the way, it took four parts before it was fixed. I'm not sure if the parts were all defective or the the labor process was an issue. The F1 system has to be bleed after installing the part.
Good luck with you situation.
CAracer is offline
post #10 of 13 Old 09-29-2013, 10:07 AM
Ferrari Life Posts: 3
hello gerytaylor.17, how did you solve the ambra light "slow down"? i have the same problem on my 430 F1.
thanks you
stefano is offline
post #11 of 13 Old 09-30-2013, 12:43 PM Thread Starter
Warning Light
Well to be honest, i stopped revving the car at stand still which i think was putting large amounts of fuel into the cats.
Since then ive had no problems with the warning light.
post #12 of 13 Old 10-01-2013, 04:42 AM
Thanks you gary.taylor17!
stefano is offline
post #13 of 13 Old 10-01-2013, 04:55 AM
Scuse me Ferraricyprus, If you have an ambra light slow down and SD3 diagnostic problem that says "failure on accumulator" on F430F1 what kind of repair do you keep?
Discharge me for bad english
Thanks you
stefano is offline
