F430 Capristo valve remote control on scud - Ferrari Life
post #1 of 38 Old 02-06-2013, 03:50 PM Thread Starter
Ferrari Life Posts: 166
Is it necessary to turn off battery to install capristo valve remote control?
Jrodrig688 is offline
post #2 of 38 Old 02-06-2013, 05:44 PM
Ferrari Life Posts: 2,526
Stef would be the one who would know. I believe there is a thread on installation of it. Might search in the 430 area.
markjayw is offline
post #3 of 38 Old 02-06-2013, 07:48 PM Thread Starter
I'll search. Thanks
post #4 of 38 Old 02-06-2013, 09:11 PM
chenglo1's Avatar
Ferrari Life Posts: 531
Diy
jose,
ya gonna DIY? Go for it!
Cheng
chenglo1 is offline
post #5 of 38 Old 02-06-2013, 10:32 PM
Ferrari Life Posts: 2,381
Hi Jose, no there is no need to disconnect the battery to make this installation. Just leave the ignition key turned off while you do this. Good luck with the install
StefVan is offline
post #6 of 38 Old 02-07-2013, 02:16 AM Thread Starter
Thanks for the replies. I'll post some pics. Parts should be here today. Ordered from them directly They are in FL. If I receive package today will do it.
post #7 of 38 Old 02-07-2013, 02:16 PM
Great, take some pictures, want to do this on my 16M. Want to hear how hard it is. I am not very mechanically inclined, but I would try.
markjayw is offline
post #8 of 38 Old 02-07-2013, 02:54 PM Thread Starter
Remote system installed. I removed the rear diffuser which made it much easier. I dropped the Allen wrench a couple times. If diffuser would have been on I would of had to remove it. Accessing the connections on the left side is much easier from the bottom. I'll post some pics tonight. Not a difficult job. Remote works great.
post #9 of 38 Old 02-07-2013, 03:15 PM
Did you put it on a lift?
markjayw is offline
post #10 of 38 Old 02-07-2013, 04:26 PM Thread Starter
no lift. used a towel and lay down. plenty of space
post #11 of 38 Old 02-07-2013, 04:27 PM Thread Starter
Before pic on left with side panel removed.
post #12 of 38 Old 02-07-2013, 04:28 PM Thread Starter
after pic with side panel removed. ground wire = red
antenna = yellow arrow
post #13 of 38 Old 02-07-2013, 04:31 PM Thread Starter
bottom view of left side controller with connection done. easy when done from bottom of car
post #14 of 38 Old 02-07-2013, 04:32 PM Thread Starter
right side controller with pannel off. top view. cant be done from the bottom.
post #15 of 38 Old 02-07-2013, 04:34 PM Thread Starter
then just run long cable from right to left towards the ecu and yellow zip tie. bottom of car view. its tied to the vaccum hose runnining across to vacuum container on left
post #16 of 38 Old 02-07-2013, 04:38 PM Thread Starter
then put the panels back on. put the rear diffuser back on and done. by the way the fins on the CF rear diffuser are removable. they are attached with screws. I was wondering that a while back.
post #17 of 38 Old 02-07-2013, 04:48 PM
Killer, appreciate all your work! Now we need videos! How do you like the new downshift sounds since when you select open, the valves stay open on downshift blips.
markjayw is offline
post #18 of 38 Old 02-07-2013, 05:07 PM Thread Starter
Sounds great. Very aggressive. Love it.
post #19 of 38 Old 02-07-2013, 05:16 PM Thread Starter
CF diffuser and screws.
post #20 of 38 Old 02-07-2013, 05:17 PM Thread Starter
Fin screws that is.
