F430 Lighting upgrade - Ferrari Life
post #1 of 15 Old 05-17-2012, 05:52 AM Thread Starter
Pooya's Avatar
Ferrari Life Posts: 197
Lighting upgrade
I didn't like the License plate lights of my car. It is yellow and looks dim.
The other problem was the inside study lamp which makes too much heat. sometimes I feel it can burn the plastic cover.
So there are easy upgrades I made and want to share it with you.
1) Plate lamps > LED :
This is philips LED lamp
There is a real different feeling when you have pure white color there :
Result :
2) Study lamp > LED :
Not only it doesn't produce too much heat but also it is nicer color in nights.
Don't choose 6000 for illumination otherwise it will be too much light in the cabin.
Result :
3) Front box lamp > LED :
Easy Upgrade on this :
more light.
4) Front Parking lights
They can be easily replaced by a 6W LED. Today the shop was out of stock for LED with turn-lock base. if you are not looking for a lot of headache to replace it with LED stripe, you can just replace that small bulb from the gate on top of the front tyres and replace it with a 6000K 6W LED light and you will get white stripes. (won't be as perfect as LED stripe)
F430 F1
Pooya is offline
post #2 of 15 Old 05-17-2012, 07:44 AM
Falcon7x's Avatar
Ferrari Life Posts: 49
Thanks!
Falcon7x is offline
post #3 of 15 Old 05-17-2012, 12:02 PM
Ferrari Life Posts: 2,315
Thanks for sharing, nice light upgrades. I have a question though. Didn't you have issues with the dome light when switching between the 'doors open' and 'permanent on' switch position? These 2 switch positions are inverting the polarity and LEDs are polarity depend (you can't inverse - and +). I had this issue when I created the fade in/ out dome light DIY and had to leave a normal bulb to preserve both functions of the switch.
post #4 of 15 Old 05-18-2012, 03:27 AM Thread Starter
Pooya's Avatar
There are two grounds and one + and one - LED is a diode so doesn't let the current to reverse. I cut one base of the other diode in the box and gave a share of the ground to the ( - ). So it will be like this:
(+) gr1 gr2 (-) (for door)
(+) gr2 (-) for permanent
I'm sure if place or any other lamp which is being checked by the car could cause error in the system. but study lamp seems to be non-important.
Option 2:
The Philips sells 2 poles LEDs both side is white. I will go to shop to send a picture of the box and model so you can order those. I couldn't use them because it was blue/red 2 poles.
F430 F1
Pooya is offline
post #5 of 15 Old 05-18-2012, 10:36 AM
Ferrari Life Posts: 7
Really nice and inexpensive mod., gives car modern appearance at night.
For the c5w philips led license plate light, which one to use, 4000 or 6000 illumination?
wildkalabaw is offline
post #6 of 15 Old 05-18-2012, 10:45 AM
champagne612's Avatar
Ferrari Life Posts: 10,021
I like it!
Wish you guys were closer and we could all do these upgrades together.
Which means I buy beer and watch
FF 16M Speciale
Lamborghini SV Roadster
Carrera GT GT3RS Viper ACR
Bentayga 69z28 Healey
champagne612 is offline
post #7 of 15 Old 05-19-2012, 11:28 AM Thread Starter
Pooya's Avatar
Good question! Forgot to say that,
1) Use 4000L it is stronger than enough. (First I used 6, then changed it to 4)
2) Angel them to lightup license plate. not straight down.
P.S: If you use 6000L or angel the LEDs in straight down. Ground below the diffuser will light-up and it will be like Honda floor light upgrade.
P.S2: for the front box light use 6000L.
F430 F1
Pooya is offline
post #8 of 15 Old 05-20-2012, 09:43 PM
For the front park light, I'm having difficult time fitting the led strip.
What is the best and brightest c5w led lights you recommend?
post #9 of 15 Old 05-21-2012, 11:34 PM Thread Starter
Pooya's Avatar
LED is difficult job. there is step by step guide here in this forum. I did fix a led lamp instead of the regular one. so I get white stripe. (but no angel eyes).
I will send photos soon.
F430 F1
Pooya is offline
post #10 of 15 Old 11-05-2013, 12:44 PM
Ferrari Life Posts: 166
Anyone know if the bulbs for the license plate are the 38mm or 43mm?
festoon c5w come in these two sizes.
Jrodrig688 is offline
post #11 of 15 Old 04-15-2014, 09:16 AM
I don't have access to my F430 right now, did you find out the length?
MolsonB is offline
post #12 of 15 Old 04-17-2014, 09:55 AM
I have not measured them. Ill prob do that today or tomorrow now that you asked.
post #13 of 15 Old 04-17-2014, 10:53 AM
RichardCH's Avatar
Ferrari Life Posts: 409
I'm sure your local Police dept will be very happy that you illuminate the plates more
RichardCH is offline
post #14 of 15 Old 04-17-2014, 11:26 AM
Funny, that's exactly what I thought too! The plates are the last thing I would illuminate better especially with the new severe road laws here in Switzerland.
post #15 of 15 Old 04-22-2014, 11:53 PM
Ferrari Life Posts: 3
If it's like the 360 it's 38mm X 1.5 but the 36mm will work as well.
ferraristyle1 is offline
