Today when I reached back home after playing in roads around in the parking I've seen the place shown in the picture is kind of red hot. (glowing red in the parking's dark) is that normal?
The stock catalyser usually shouldn't glow red or it is a sign that you've driving it a bit too hard if not, something else is wrong. This can lead to a converter meltdown. The main reason is raw fuel conditions, I mean, too enriched A/F mixture. I would check your cats for signs of heat discoloration. You can check easily your cats with a OBD tester and log the data while you're driving. Maybe there is nothing to worry about as the air temperature is very warm there.
Drove it hard. not too hard (a few hard acceleration, speed up to 270 km/h) then slowing down on 50-90 km/h for 5 mins. Totally like showing the car to my friend who is aston owner to be ashamed.
The red hot was about one inch in the pipe front of catalyser. Air temp here was 38C.
Do you think I need a tech to come with me to test drive and check conditions?
I would test drive it again in the same conditions as you did. If only one cat (one side) is glowing red and not the other side, then yes, you better check it with your dealer.
I've never seen my cats glowing red but the outside temperature isn't 38°C neither
Related Threads
Ferrari Life Forum
325.1K posts
28.1K members
Since 2002
A forum community dedicated to Ferrari owners and enthusiasts. Come join the discussion about performance, build specs, production numbers, modifications, classifieds, reviews, troubleshooting, maintenance, and more!
