Scud/16M modification thread! - Page 41 - Ferrari Life
 8Likes
post #801 of 1518 Old 05-19-2013, 09:57 PM
430Addict's Avatar
Ferrari Life Posts: 1,075
Originally Posted by dbonvillain View Post
Just picked up my car with the final prototype completed and ceramic coating on it. All that is left is Alwin and my custom plaques and it's done and done :-)
Alwin - yours has a slightly different mount that is even a little step-up from mine...benefits of #2 I suppose :-) It really does sound perfect. Dan and Ronnie heard it today. We will get more video soon.
Looks menacing!!!
430Addict is offline
post #802 of 1518 Old 05-20-2013, 12:56 AM
16M Down Under's Avatar
Ferrari Life Posts: 1,396
Here is the pic of my LHS intake taping. It only takes a few minutes to do. My intake is different to the ones that Richard has shown in that the Y tube is on the outside of the curve and it does not have a resonator box on the other side. I am happy with the result and will report if any unpleasant sounds develop as SteVan has suggested. Thank you Richard for your advice about the drill holes but I am satisfied with my current set up. I feel that blocking the Y pipe inlet at the apex of the inlet curve could encourage more steam lined laminar flow as air bends around the corner. Maybe the decreased turbulence creates a faster airflow and more noise. I am not a physicist and I am probably way off track but it has been the best I have found without resorting to a drill.
Thanks Taz regarding the valve delete advice. I have been running like that since I bought her. But that 3K drone is problematic. I find myself changing down to 5th whilst cruising to avoid it. I suppose its a small price to pay to avoid that standard muffler note but there must be a better system. I am looking forward to see what develops with these new x-pipe setups from Alwin and dbonvillain.
Thanks Taz for the advice and Ill look into the Tasmania Targa for next year. Keeping one eye in the rear vision mirror if you dare go over 100 kph is no way to drive a Ferrari! My wife and I are holidaying in Europe next month and I might even be able to experience some of your autobahns!
16M Down Under is offline
post #803 of 1518 Old 05-20-2013, 01:24 AM
RichardCH's Avatar
Ferrari Life Posts: 416
Interesting to note that unlike the 430 Spider there is no sound box on the inside at the junction of the Y
RichardCH is offline
post #804 of 1518 Old 05-20-2013, 02:02 AM
Maybe Richard we have different noise regulations down here, so different specs? For example, not many US 16M's have LC where it is the norm here.
post #805 of 1518 Old 05-20-2013, 05:44 AM
Ferrari Life Posts: 50
Originally Posted by alwin View Post
You didn't get it high polished!? the placard is going to look so nice! Can't wait to see it on there.
I figured I would let you get the one that had the bling :-) and that way we had a design in both configs for pics or whatever
dbonvillain is offline
post #806 of 1518 Old 05-20-2013, 05:55 AM Thread Starter
Russell996's Avatar
Ferrari Life Posts: 700
It's a hard mount that bolts onto the engine and is welded there under the cross section. I can grab a pic of it on mine, and probably of Alwin's before it goes out if y'all want.
Yes please.
Russell996 is offline
post #807 of 1518 Old 05-20-2013, 12:16 PM
alwin's Avatar
Ferrari Life Posts: 472
Originally Posted by Russell996 View Post
Yes please.
Mine's getting polished and the plaque put on, then as donb said earlier, done, done & done.
I will be dyno'ing my car this week, then again after I install our x-pipe. dyno charts to come
alwin is offline
post #808 of 1518 Old 05-20-2013, 07:57 PM
Okay - audio still sucks, but just ran a handheld cam from inside the cabin to try and get a feel for how (relatively speaking) quiet it is inside, yet wails like a banshee from outside - which we still have to get with Ronnie and gang. This weekend should work hopefully.
http://www.youtube.com/watch?v=hLj07wagpok
post #809 of 1518 Old 05-21-2013, 01:00 AM
Sounds good dbonvillain. Looking forward to seeing and hearing the video from the outside, together with Alwin's dyno results. Can you configure it to be a 'bolt on' unit utilising existing mounts, without having to weld supports?
post #810 of 1518 Old 05-21-2013, 06:08 AM
That's actually the config now - it's welded onto the pipe, the support bolts on the engine. I'll go grab a pic with my phone right now for you guys.
post #811 of 1518 Old 05-23-2013, 05:55 AM
You can see the gen1 mount on these pics where Dave was weighing the stock system and the F1 exhaust for me.
post #812 of 1518 Old 05-23-2013, 11:53 AM
RichardCH's Avatar
So what happens to the exhaust valve ?
post #813 of 1518 Old 05-23-2013, 01:10 PM
430Addict's Avatar
Non existent?
post #814 of 1518 Old 05-23-2013, 03:34 PM
hrf scuderia's Avatar
Ferrari Life Posts: 54
Richard, there are a number of manufactures around the world producing valveless Scuderia systems, all with their own unique characteristics IE . particularly sound, heat and weight variants.
Hugh,
Current: 430 Scuderia.
Coustodian:365 GTB/4, 365 BB, 246 GTS, 308 GTB gf
Past: 308 GTB, 328 GTB, 360 Modena.
hrf scuderia is offline
post #815 of 1518 Old 05-26-2013, 07:15 AM
LC = Launch Control right?
All the Scuds 'have' LC I believe...just not all with the little button in the center console. Isn't that the case?
I haven't launched mine yet, but I thought there was a procedure that enabled it (something like in CST off, 1st gear, hold left shift lever for a second, LC flashes on the center display), lift off brake, floor throttle and it rips balls off the line.
(that last part I am not sure about as to whether you keep the brake down and hold the throttle and let off the brake, or whether you just lift off the brake and floor it. But all of that seems fairly logical as that's how the Gallardo did it's launch as well. )
post #816 of 1518 Old 05-26-2013, 07:47 AM
alwin's Avatar
To engage actual launch control:
Turn the manettino to CST off (LC is only selectable w nanny controls off as far as I know)
Put it into neutral
Hold down on your brake pedal
Engage first gear and hold until an “L” appears on the dash
Let 'er rip!
I have never launched my car, but I have put it into LC just to see if its actually available
Enjoy.
alwin is offline
post #817 of 1518 Old 05-26-2013, 10:09 AM
Ferrari Life Posts: 2,526
Put it into neutral
Engage first gear and hold until an L appears on the dash
Let 'er rip!
Enjoy.
It is engaged from left paddle, CST off, car in 1st gear, pull left paddle back until flashing "L", left foot brake, floor throttle, should hold around 4k rpm, release brake and floor throttle at same time.
markjayw is offline
post #818 of 1518 Old 05-26-2013, 10:09 AM
Impressive weight savings!
markjayw is offline
post #819 of 1518 Old 05-26-2013, 02:17 PM
You are right, I should have said that we have been specked with the LC button. How's that x pipe going?
post #820 of 1518 Old 05-26-2013, 04:12 PM
Laser etched plaques are done this week and Alwin's is out the door. Dave is making at least 2 more for the Scuds so nobody else has to wait, and pretty sure Jeremy's 430 spyder is going in next week or the week following for the new F430 design.
IMO it couldn't be any better. But guessing high flow cats and headers wouldn't do any harm...perhaps later :-)
Ronnie, Dan, jeremy and a few other folks were just on a drive with me though, they may chime in with their thoughts.
we got some fresh video too.
