430 CCM Brakes - Ferrari Life
post #1 of 33 Old 03-18-2012, 06:59 AM Thread Starter
champagne612's Avatar
Ferrari Life Posts: 10,022
430 CCM Brakes
Originally Posted by Boxer View Post
As of this morning, now have two options, a black/black and a blue/tan. Both have F1 gearboxes. Black one is fitted with CC brakes.
The CC brakes on the 430 have great feel - let alone easy to clean.
They look 1000x better - also no rust or weird discoloration inside the wheel.
My brakes at near 7,000 are at 4% wear - pretty impressive!
Washed the car yesterday - can't tell you how nice it is not having to deal with brake grime everywhere,
champagne612 is offline
post #2 of 33 Old 03-18-2012, 08:34 AM
Ferrari Life Posts: 53
Depends on the other tick boxes, having flash backs on searching for the right car, CCB do fill the alloys well
RevHappy is offline
post #3 of 33 Old 03-18-2012, 09:10 AM
Ferrari Life Posts: 15,131
The CCBs do fill the alloys nicely. Will let you know as this unfolds over the next couple of weeks.
post #4 of 33 Old 03-18-2012, 09:29 AM
I'm always surprised by the variation in spec on 430's. The old 360 only had a few possible option which made it an easier search. Good luck I'm sure you'll do ok
RevHappy is offline
post #5 of 33 Old 03-18-2012, 02:42 PM
Ferrari Life Posts: 11,859
Boxer- Those CCMs should last the life of the car unless you track her. If you intend to track her, I would go with steel brakes or, better yet, buy a set of the steel rotors and pads Brembo makes that will fit the CCM calipers. When it comes time to sell, reinstall the CCM rotors and pads. If you do that, have your technician change the brake selection in the instrument panel 8 Mb chip to steel from CCM.
Like Doug said, a really nice feature of the CCMs is little to no brake dust. My ceramics are Mov'Its and there is no brake dust.
post #6 of 33 Old 03-18-2012, 04:39 PM Thread Starter
Terry why are the CCM brakes so expensive - I understand it's carbon ceramic but given the demand?
I was told it takes under 60 minutes if you want to switch your car to steel for track days.
The more I learned about the CCM's - the more I realized it was as important for me have them as it was the F1 vs the
6 speed shifter.
post #7 of 33 Old 03-18-2012, 09:50 PM
Doug- Ferrari prices and a monopoly for the car companies that use the brakes. Brembo apparently agreed not to sell the parts aftermarket.for those companies that use them. Corvette Brembo prices are a fraction of the Ferrari prices, but the rotors are not interchangeable. You could probably buy a complete set of ZR1 brakes for around $10K. The option on Ferraris was $15-20K, depending on model, when they were optional.
1 CF rotor....
GM PART # 25843121
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $1,695.00
OUR PRICE: $1,233.96
Ferrari wants $8000 for one of them.
Tried to get Mov'It to make rotors and pads for the CCM calipers, but they are too busy sellling brakes to Porsche for the GT2/GT3 and to Lotus for all their street cars. They are also a Lotus F1 sponsor this year. The Mov'it CER rotors are solid CSC (carbone silicon carbide) and nearly indestructible, even if tracked. Expensive, but the rotors never wear out.
post #8 of 33 Old 03-18-2012, 11:57 PM
Is there any reason on why rotors made out of clay and charcoal are so expensive? Materials and manufacturing process would not seem to justify it.
post #9 of 33 Old 03-20-2012, 07:02 PM Thread Starter
1 CF rotor....
GM PART # 25843121
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $1,695.00
That is just insane!
Some car besides a 430 has to share that brake set up.
Mov'it should sponsor you
post #10 of 33 Old 03-20-2012, 07:11 PM
Doug- There is a car that shares the F430 CCMs, the CS, and the price is the same. The Scud/16M have the same rear brakes/rotors, but larger (398 mm vs 380 mm) front rotors and different front calipers. Porsche CCBs are similar, but there are detail differences, as there are on the Corvette brakes. The brakes are only about a $9K option on the Porsche last time I checked, and the Corvette CCMs are even cheaper.
No different from any other Ferrari part. The TPMS sensors on your 612 are available for about a third of the price Ferrari charges for them through TireRack. Somebody has to pay for that little yellow box.
post #11 of 33 Old 03-20-2012, 07:15 PM Thread Starter
LOL - true story.
post #12 of 33 Old 03-21-2012, 02:02 PM
Carbon- Except for the algorithms, no reason why you cannot just replace two on the same axle, just like steel rotors. Those algorithms are just estimates, at any rate, and can be reset with an SD2/3.
CCMs are great for the street, but just wear too fast on track days and are too expensive for that. Swapping the rotors for Brembo steel and appropriate pads is not that difficult or expensive compared to replacing $8K each CCM rotors.
post #13 of 33 Old 03-24-2012, 06:40 PM
134282's Avatar
Ferrari Life Posts: 386
Just saw this - didn't know that, Terry, thank you! I was under the impression that if something happened to one rotor, all four needed to be replaced - I didn't know that you could just even things out on a single axle.
I need an Aventador!
134282 is offline
post #14 of 33 Old 03-24-2012, 06:44 PM
Carbon- If you look at Stef's thread on the Texa diagnostic tool, the F430 system tracks wear and heat cycles by axle, so there is even less need to make a wholesale change. I would expect the fronts to go quicker than the rears, even though they are bigger (380 mm vs 350 mm) and have 6 piston calipers.
post #15 of 33 Old 03-25-2012, 10:16 AM
Ferrari Life Posts: 2,343
Except if you track or drive hard the car in Sport mode or lower. Then the ASR may brake a lot the rear wheels and result in a higher wear on the rear axle
StefVan is offline
post #16 of 33 Old 03-25-2012, 03:19 PM
Stef- Affirmative and that also frequently causes the E-Diff to overheat for the same reason.
post #17 of 33 Old 03-26-2012, 01:02 AM
Doug, as you can see in the TXC tool details, I got 6% calculated wear in 25000km/15500miles which includes a lot of hard driving on mountain roads (especially downhill)
StefVan is offline
post #18 of 33 Old 03-26-2012, 05:44 AM Thread Starter
That is incredible!
I am sending my car up to Chicago for a service and will ask for wear data at 6700 miles.
post #19 of 33 Old 03-26-2012, 06:06 AM
johan6504's Avatar
Ferrari Life Posts: 230
Do you know how many brake pads that has been used during this time?
Ferrari 430 Scuderia 2008/12
(Ferrari 355 GTS F1 -99)
(Ferrari 355 GTS F1 -98)
johan6504 is offline
post #20 of 33 Old 03-26-2012, 06:47 AM
Still the first set and I'm far of having them worn out. But I don't track my car, well, maybe I will do 1 session this year
StefVan is offline
