F430 Side air intakes - Ferrari Life
post #1 of 9 Old 03-19-2012, 01:54 AM Thread Starter
Ferrari Life Posts: 119
Side air intakes
Hi lads,
I seem to have splatter marks off the polisher in the air intakes on the sides.
Can you easily remove the grills ?
gary.taylor17 is offline
post #2 of 9 Old 03-19-2012, 03:05 AM
Ferrari Life Posts: 2,340
Hi Gary,
To remove the air intake legs, you'll have to remove all 4 engine bay panels. From there, you'll be able to access the 3 nuts which hold these intake legs to the body. Be carefull to not loose the nuts, otherwise, you'll have to remove the rear wheel + mudguards to find back the lost nut (happened to me ). Once you've removed the rubber join between the intake leg and the airbox, you can pull out carefully the entire intake. When you refit everything make sure you place the rubber join in the right direction (check the arrow marked on it).
post #3 of 9 Old 03-19-2012, 03:12 AM Thread Starter
Once again thank you very much Steve.
post #4 of 9 Old 03-19-2012, 03:28 AM
You're very welcome Gary.
I marked on the picture where the 3 nuts are located. I hope you have long arms to access them, especially the lower one
post #5 of 9 Old 03-20-2012, 02:15 PM Thread Starter
Your a genius.
Is there anything you get stuck with lol
post #6 of 9 Old 03-20-2012, 03:08 PM
LOL, thanks Gary The F430 is a quite "simple" car and really a pleasure to work on as everything is quite accessible. What is a real challenge is what can't be seen or touched...the ECU's software
Good luck with this job and don't hesitate to give a shout if you need something.
post #7 of 9 Old 03-20-2012, 05:42 PM
netman's Avatar
Ferrari Life Posts: 226
For future reference painters tape can be used to cover up the grills and prevent this splatter.
netman is offline
post #8 of 9 Old 03-20-2012, 11:19 PM
BTW Gary, forgot to mention that you have also to remove the screw in the middle of the intake (see #10 on the above diagram). This screw attaches the intake to the rear wheel mudguard. Make sure to not tighten this screw too much because the next time you'll have to remove the mudguard or the intake, you'll get in troubles. In the mudguard, the nut is locked in only a plastic housing...
post #9 of 9 Old 03-21-2012, 12:22 AM Thread Starter
I honestly would have bought one of these earlier if I knew people like you and a few others where this helpful.
