360 360 air filter compartment nuts broken - Ferrari Life
post #1 of 17 Old 12-06-2011, 06:51 AM Thread Starter
F1fanforlife's Avatar
Ferrari Life Posts: 244
Any advise appreciated.
Installed Carbonio air box covers and while removing the old covers I noticed that two of the ear/bolts on the filter housing was hanging by a thread. Still tried to install and when I did the two rear bolts came off. Hope I explained this to make sense. Any ideas besides replacing the filter housing.
Thanks.
F1fanforlife is offline
post #2 of 17 Old 12-06-2011, 10:37 AM
a1exander's Avatar
Ferrari Life Posts: 1,094
If I understand you correctly the nuts welded under the filter housing came loose?
If so remove the filter housing and get them re welded.
Quickest way to align the ears with the nuts would be to take the cover of the housing as well as the housing to a welder fit the top of the air filter housing to the bottom piece and align the broken parts to be welded.
Hope this helps
a1exander is offline
post #3 of 17 Old 12-06-2011, 10:48 AM
Ferrari Life Posts: 11,858
Kevin- Assume you mean the nuts that hold the eight screws (3) below came loose?
Epoxy might be another solution without wiping out the finish on the filter housing.
Of course, there is always the OEM carbon fiber filter housing available. Should not be much more than $8-10K.
Note that there is a different mounting system for the CF air filter housing, which you might be able to adapt to your filter housing. It uses studs and nuts rather than the welded on fittings of the base housing.
post #4 of 17 Old 12-06-2011, 10:50 AM Thread Starter
Hope this helps
Yes you are correct. Thanks for the advise. Certainly sounds like a method to consider. Much appreciated.
BTW, I was born and raised in JHB. Left in 92 and have not been back since. Need to get back soon for a vacation. Miss the Cape and Kruger.
Thanks again for your help.
Kevin.
post #5 of 17 Old 12-06-2011, 10:57 AM Thread Starter
Yes Terry you are correct. Thanks for the advise. Epoxy is a good idea. Will it hold up to the heat though being on the exhaust side?
I do like your CF idea. It was tough enough getting the wife to agree on the covers
post #6 of 17 Old 12-06-2011, 10:58 AM
a1exander's Avatar
Kevin.
A pleasure.
Try and make it back, SA still remains a magnificent country irrespective of the shenanigans that do on occasion surface.
We have a lot to be gratefull for......ja nee.
post #7 of 17 Old 12-06-2011, 11:02 AM Thread Starter
A pleasure.
Will definitely be back to show the wife and kids, in the next few years. Can't argue that it is beautiful.
Cheers.
post #8 of 17 Old 12-06-2011, 12:21 PM
Kevin- I edited my post when I noticed the CF part has a different mounting system. Might be adaptable to the two spots where the parts are broken.
There are high temperature epoxies. The short bonding type will probably not be what you want.
post #9 of 17 Old 12-06-2011, 01:50 PM Thread Starter
Thank you Terry. I will be checking out the options. Josh at ECS has an idea of fabricating a bracket that will be nice and secure for future maintenance. Much appreciated.
Kevin.
post #10 of 17 Old 12-06-2011, 05:34 PM Thread Starter
Problem solved
Managed to get the cover attached using the original bolt and nut. There is a lip on the filter compartment that allows the bolt and nut to be tightened adequately. Works just fine. Thanks to all that provided input. Much appreciated.
Kevin.
post #11 of 17 Old 12-06-2011, 08:46 PM
Looks fine.
post #12 of 17 Old 12-07-2011, 05:57 AM Thread Starter
Looks fine.
Thanks Terry. For a finishing touch I would like to either get some black bolts or just paint these black.
post #13 of 17 Old 12-07-2011, 07:58 AM
Kevin- I was thinking the same thing. Paint the screw and nut black and square the nut up with the housing and nobody would notice it at all.
Try McMaster-Carr. They carry black screws and nuts.
post #14 of 17 Old 12-07-2011, 08:12 AM
a1exander's Avatar
You can also boil the bolts and nuts in engine oil...preferably used non synthetic.
They will turn out black.
Make sure you do it using your wife's AMC S/S pots and without the extractor on.
If you make it alive come and tell us how they turned out.
post #15 of 17 Old 12-07-2011, 08:49 AM Thread Starter
Thanks. I will check them out.
post #16 of 17 Old 12-07-2011, 08:50 AM Thread Starter
Should I keep the windows open or closed?
post #17 of 17 Old 12-07-2011, 10:42 AM
Kevin- Depends on how loudly your wife is yelling at you.
