360 Coolant Depth Gauge - Ferrari Life
post #1 of 4 Old 09-07-2009, 04:59 PM Thread Starter
Ferrari Life Posts: 3,627
If you have ever enjoyed the fun of changing the coolant in your 360 (more to come on this) you know that one part is determining a correct level after bleeding and after the car has fully cooled.
The W/S manual says 40 mm but how does one accurately measure that while one is pouring in additional coolant?
Well I twisted a coat hanger wire to sit on the the filler neck and on the top of the tank with the depth gauge set to the required 40 mm level per the W/S manual.
Total length of the downward leg is about 60-62 mm which yields right about the 40 mm required depth.
I made a semi-circular twist on the bottom portion so I could see the antifreeze level rising and leveling to that point as I poured it in.
I'd make the outer top loop for a 2nd model about 2" in diameter to ensure that if it were accidentally bumped it would not fall into the resevoir.
Gcalo is offline
post #2 of 4 Old 09-08-2009, 09:17 AM
Ferrari Life Posts: 6,203
Nice job. Put a part number on that and tell Ricambi.
post #3 of 4 Old 09-08-2009, 09:58 AM Thread Starter
That's too inexpensive of an item for Daniel!!!!!
Gcalo is offline
post #4 of 4 Old 09-08-2009, 02:18 PM
cool to the idea? You should have shields on that hanger, or up it to titanium
