599 Boot Wiring Harness Gasket - Ferrari Life
 1Likes
  • 1 Post By David @ FluentInFerrari
post #1 of 11 Old 04-03-2019, 08:43 PM Thread Starter
Ferrari Life Posts: 39
Greetings,
My 599 has a split gasket. I have searched high and low for a replacement with no success. Does anyone have a lead for me to follow? Barring that, has anyone found a aesthetically pleasing solution to repair this?
Thank you,
Rick
[email protected] is offline
post #2 of 11 Old 04-05-2019, 05:29 AM
Ferrari Life Posts: 966
Short of sourcing and replacing the harness....I'd consider two options:
Some sort of adhesive to bond the harness cover
Replace the corrugated section with some split loom. You'd still have to bond the split loom to the end pieces. This solution would resemble the original look.
post #3 of 11 Old 04-05-2019, 07:57 AM
Ferrari Life Posts: 451
Originally Posted by [email protected] View Post
Greetings,
Thank you,
Rick
Hello Rick,
this company have the parts for restore cable connections, maybe could be adapt for you , followings the links to their website, catalogue and contact, they are in Germany but perhaps they have also dealers in US, you coud send them an email.
https://herthundbuss.com/blaetterkat...04EN/#page_274
https://herthundbuss.com/en/products/elparts/range/
Herth+Buss Fahrzeugteile
GmbH & Co.KG
Dieselstraße 2-4, 63150 Heusenstamm, Germany,
I hope can help you.
Fabio Fiammenghi
post #4 of 11 Old 04-05-2019, 09:12 AM Thread Starter
Thank you both for the suggestions. As for option one: If I can find the matching grommet corrugation spacing, I was entertaining cutting some that may be ~10cm long, cut out about 1/3 of the circumference so it would fit inside and use a glue to bond one side, then once it is cured repeat for the other end and just a bit at the original grommet interface. I will have to devise a fixture that will let me a force on it while it cures.
As for the catalogs, I'll peruse those and see if there is something that RTGT would be able to adapt.
Thank you again. I will post what ends up being the solution.
Rick
post #5 of 11 Old 04-05-2019, 03:36 PM
George Vosburgh's Avatar
Ferrari Life Posts: 31
Rick, have you tried Eurospares? They have a LOT of parts!
https://www.eurospares.co.uk
George Vosburgh is offline
post #6 of 11 Old 04-10-2019, 03:43 PM
Ferrari Life Posts: 28
Cyanoacrylic "Crazy" glues work incredibly well on rubber like materials. We used to use it to repair rubber drive belts in cassette players. You can hold it in place long enough for it to bond. It's worth a try.
apexdc is offline
post #7 of 11 Old 04-10-2019, 06:49 PM Thread Starter
Hi George,
Thank you for the lead. I couldn't find the part in their catalogue list, but I did send an inquiry.
Best regards,
Rick
post #8 of 11 Old 04-10-2019, 06:51 PM Thread Starter
I sent an inquiry to Eurospares with a picture. I could not tell from their diagrams if this was listed or not. Thank you for the heads up. - Rick
post #9 of 11 Old 04-10-2019, 06:54 PM Thread Starter
Thank you. I like the cyano acrylics and to your point they bond quickly. I need to do some dry runs with spare parts to see if I can be fast enough before it bonds. I have tried pulling the two pieces together with the boot open. It is amazing how much force is need to get them to connect. In my opinion, this is one of the reasons it has failed: there is too much strain on the rubber when open. This should be a very low strain designed part.
Rick
post #10 of 11 Old 04-16-2019, 10:49 AM
Rick, I know that Claudio always likes to confirm with a picture just to make sure he's talking about the correct part.
post #11 of 11 Old 04-24-2019, 04:06 PM Thread Starter
Hi George,
Unfortunately, I haven't heard back from Eurospares. I'm guessing they don't have it.
Rick
