575 Starting Problem - Ferrari Life
post #1 of 10 Old 06-13-2016, 02:14 PM Thread Starter
Ferrari Life Posts: 3
My 2005 575 turns over strongly but will not start. It has a P 1611 error code but this could be in the system from a past fault. Any ideas? Thanks
Phil Williams is offline
post #2 of 10 Old 06-13-2016, 02:36 PM
550_Maranello's Avatar
Ferrari Life Posts: 1,232
Ciao Phil,
Could be the immobilizer .... And also If i remember correct P 1611 is the immobilizer ECU error .
Can you post some Pics of your Maranello?
Best regards from Italy
Fabio
550_Maranello is offline
post #3 of 10 Old 06-13-2016, 06:53 PM
Phil- Do the simple stuff first. Change the battery in the fob, pinch the contacts closed before inserting, and spin to make sure there is no corrosion. Unlike earlier Ferraris, the 575M will turn over fine while immobilized. More details:
File Type: doc Programming Alarm ECUs with New Fobs.doc (2.04 MB, 230 views)
post #4 of 10 Old 06-14-2016, 06:56 AM
Ferrari Life Posts: 535
Terry what if your 575 is starting but just seems to be taking longer to turn over? I just had my battery changed last year so the 575M battery is effectively new, but I believe my FOB battery may be dying. I forget the battery type I need to buy, can you remind me again please? Thanks in advance.
Clyde
tifosi_ is offline
post #5 of 10 Old 06-14-2016, 10:33 AM
Clyde- The fob batteries have nothing to do with how fast she turns over. Only your main battery determines that. Fob battery type is in the document I posted above.
post #6 of 10 Old 06-14-2016, 10:41 AM
Thanks Terry
Clyde
tifosi_ is offline
post #7 of 10 Old 06-14-2016, 12:56 PM Thread Starter
Thanks taz - have done that & no joy!
post #8 of 10 Old 06-14-2016, 12:58 PM Thread Starter
Thanks Fabio - that makes sense - feels like an immobiliser issue. Will check further
post #9 of 10 Old 06-15-2016, 01:27 AM
Ciao Phil,
sorry about your error code i bad remembered ...
I check on F575 error codes manual and the error is "supply voltage too low" as per attached picture.
But if the start engine give regular speed, i think however could be the immobiliser ....
Best Regards
Fabio
post #10 of 10 Old 07-14-2016, 08:57 PM
Hi Paul,
Did you solve starting problem?
Regards
Fabio
