Ferrari 550 Fusebox - Ferrari Life
post #1 of 16 Old 07-03-2014, 02:08 AM Thread Starter
darnaut's Avatar
Ferrari Life Posts: 38
Ferrari 550 Fusebox
Hi everybody,
I have one question; Does someone know something about the differences between the fuseboxes of the F456, F456MGT and the F550? Maybe my fusebox have some errors (Lost of the front fans, the aircondition and blower, the blinker, the outdoortemperature, the filler cap and the outside mirrors) - no fuse is gone, all relais are ok...
Is there a possibility to repair a fusebox inside - there are many boards connected together inside so it seems to be tough to check or repair something.
Many Greetings Chris
darnaut is offline
post #2 of 16 Old 07-03-2014, 05:48 AM
Ferrari Life Posts: 2,206
Chris,
First try swapping relay N in the illustration below with relay Q and see if it helps with any of the dead circuits.
Relay N controls all the key operated circuits. If it fails, it will knock out many things.
Relay Q is supposed to control the low beam headlights.
Along with the other things you mentioned, relay N is supposed to control the starter, injectors, and ignition as well, so if your car is still starting and running OK, the problem may not be this relay, but it's quick, easy & free to try, before you have to dig deeper for more expensive and difficult solutions.
post #3 of 16 Old 07-03-2014, 06:13 AM Thread Starter
darnaut's Avatar
Hello John,
Thanks for your reply! The car is running well except the mentioned failures - no messages from the boardcomputer, everthing seems to be fine but i will follow your suggestion - maybe it helps?
greetings Chris
darnaut is offline
post #4 of 16 Old 07-03-2014, 08:24 AM
Chris- You can download a 550 workshop manual for free at ferraridatabase.com. Same for the 456 and 456M and there is an expanded Section L for the 456M, too.
post #5 of 16 Old 07-06-2014, 11:15 PM Thread Starter
darnaut's Avatar
Thanks for this Link :-)
Now it's sure, my fusebox is damaged :-( the car is driving but with no frontfans and blinker etc. i will compare both workshops with the electricity boards - maybe they are the same? - i hope so.
best regards
darnaut is offline
post #6 of 16 Old 07-07-2014, 01:53 AM
Chris, Russ Putnam from Ferrparts has these fuseboards rebuilt by someone, and he offers them on eBay.
I see that there's one on there today: Ferrari 550 Relay Electrical Fuse Board 164673 | eBay
Before purchasing, I would contact Russ to get the details of this. PM me if you'd like his email address.
post #7 of 16 Old 07-07-2014, 04:02 AM
bay
bay's Avatar
Ferrari Life Posts: 155
best regards
you have a photo of your fusebox damaged ?
Thank you ;
Registre 550
bay is offline
post #8 of 16 Old 07-07-2014, 06:48 AM Thread Starter
darnaut's Avatar
there is nothing to see on the fusebox when it is oppend - no optical short time overload or something like that, only the functions i had listed are gone - my car was at a ferrari dealer/garage and they asserted that failure.
darnaut is offline
post #9 of 16 Old 07-08-2014, 01:01 PM
360 Modena's Avatar
Ferrari Life Posts: 4,516
Check with Dave Helms about swapping or repairing your FB
Google him for contact info
360 Modena is offline
post #10 of 16 Old 07-08-2014, 11:45 PM
bay
bay's Avatar
Innovations - Solutions - Scuderia Rampante
328/Mondial Remanufactured Fuse Box | G.T. Car Parts INC
Registre 550
bay is offline
post #11 of 16 Old 07-14-2014, 12:32 AM Thread Starter
darnaut's Avatar
perfect car, fantastic!!!
thanks for your info!
@ all: today i received the F456 fusebox - i will tell you how it works, if i install it.
darnaut is offline
post #12 of 16 Old 07-21-2014, 11:25 PM Thread Starter
darnaut's Avatar
Some days ago i installed the F456 fusebox - the immobilizer was active afterwards and the horn's were going on - at the moment i was not able to find the reason, but it seems to be that the control for the immobilizer is not documented axactly at the workshop and is running in an other way than at the F550 fusebox - the story goes on...
darnaut is offline
post #13 of 16 Old 08-17-2014, 05:56 PM
Fuse Box Location on a 550
Hi...I am new to the forum. I was wondering if anyone knows the location of the fuse box in a 1999 550 Maranello.... My windows work intermediately and I'm wondering if it is because of a relay or warn out fuse. Thanks...
Lookoutyo is offline
post #14 of 16 Old 08-17-2014, 08:18 PM
Welcome to Ferrari Life. Download an owners manual and workshop manual at ferraridatabase.com. Until then, the fuse box is under the carpet and a panel in front of the passenger seat.
post #15 of 16 Old 08-18-2014, 08:52 PM
maranello_550's Avatar
Ferrari Life Posts: 10
Hi Chris, Dave Helms is your man to rebuild your 550 fuse box and talk to him about the gold connector Kit for your 550. If you plan to keep your car long term this is the way to go. Regards Gary.
maranello_550 is offline
post #16 of 16 Old 09-01-2014, 04:55 AM Thread Starter
darnaut's Avatar
Thank you all for your answer's and help - my diva is driving again! I was not able to repair my fusebox and so I replaced it - it's very difficult to demount the box with it's single layer principle...
cheers Chris
darnaut is offline
