550 clutch squeaks inside cabin - Ferrari Life
post #1 of 3 Old 03-11-2014, 06:33 PM Thread Starter
from the driver seat, when i press the clutch in and when I release it, the clutch pedal
squeaks. It sounds like an old door in a haunted house (that type of sound).
It sounds like a spring?
any ideas on the cause or the fix????
thanks
550forme is offline
post #2 of 3 Old 03-11-2014, 06:51 PM
With age and mileage, the grease for the pedal pivot might have dried out and gone away. You might be able to spray a lubricant in there as a quick and short resolve but ideally you would want to disassemble the pedal assembly, clean out the old grease, make sure shims and washer are in good shape, re-grease and reassemble.
Here's an exploded diagram of the assembly from Ricambi America:
Ferrari 550 Maranello Parts : Table 39 - PEDALS AND ACCELERATOR CONTROL
post #3 of 3 Old 03-12-2014, 04:47 AM
Ferrari Life Posts: 19
When I replaced my clutch control pump I tried to grease up the pedal assembly underneath before reconnecting....don't have any squeaking to speak of.
I wonder if disconnecting the clutch control pump piston from the pedal assembly would allow you to expose any squeaking coming purely from the pedal?
Regards,
Pete
moorfan is offline
